3SGE engine builders please help: unknown piece !!!
Postby Wolf_Tm250 » Fri Sep 12, 2008 2:25 am
Hello,
I'm going to rebuild a friend's 3SGE.
In the parts boxes I found a piece that, even if I built many 3SGTE, I never saw!!
It should be even fallen in the box... don't know... better if I ask you if you recognize it !!
TIA.
Wolf_Tm250
Wolf_Tm250
Postby Crimson Tears » Fri Sep 12, 2008 9:05 pm
I'm pretty sure they normally go in the union side of the power steer pump. Not 100% sure of their purpose, maybe like a little restrictor or something.
Crimson Tears
Postby Twolitre » Fri Sep 12, 2008 9:22 pm
From memory that goes in the high pressure hose at the top of the firewall near the brake master cylinder (on RHD models)
Twolitre
Postby fivebob » Fri Sep 12, 2008 9:29 pm
If it's fromthe PS pump then it should be the part highlighted here
Postby Wolf_Tm250 » Fri Sep 12, 2008 10:07 pm
fivebob wrote:If it's fromthe PS pump then it should be the part highlighted here
Thanks a lot mates,
and thank you, fivebob...
you saved me again ! :wink:
Wolf_Tm250
Wolf_Tm250
