4speed to 5speed
4speed to 5speed
Postby kris.pran » Sat Sep 13, 2008 9:28 pm
Will a 5speed manual replace my current 4speed manual gearbox. The one coming in to place is off a ep82 starlet its going into a AE100 1994 4e-fe corolla.
This is the gearbox of the starlet
http://www.trademe.co.nz/Browse/Listing ... =175789994
Is there anything else to be done while converting like anything to do with the diff or ecu.
kris.pran
Postby Mr Revhead » Sun Sep 14, 2008 12:24 pm
check the mounts
i think the mounting points on the corolla are different to the starlet
check to make sure there are bolt holes where you need the new mounts to be
