Weird problem with my ST185
Postby eViLoNe » Sun Sep 21, 2008 11:35 pm
Well, this problem has just presented itself over the last 3 days or so.
If I hit a decently sized bump in a road, or a cats-eye at decent speed, my car loses all power, it actually acts like the cars starving itself of fuel. It only does it until I release the accelerator, and then re-apply, and it works fine again.
I was thinking of a dodgy sensor, or even sensor connection, but just wanting some input before investigating the entire car :P.
- 1990 Toyota Celica ST184R
- 1996 Nissan Skyline GTS25t
Ex:
- 1990 Toyota Celica ST185
eViLoNe
Postby molex » Mon Sep 22, 2008 12:44 am
TPS possibly? Would suit the symptoms, especially if 'resetting' the tps (e.g backing off) brings it right again.
molex
Postby eViLoNe » Mon Sep 22, 2008 7:40 pm
Yeah, it's strange. I noticed tonight, even if I don't back off, itll gain power back again in about a second after it happens, just seems like fuel starvation of some sort. It's starting to bug the shite out of me.
Ex:
eViLoNe
Postby johndoe1025 » Mon Sep 22, 2008 8:42 pm
sounds like maybe a dodgy earth?
johndoe1025
Postby eViLoNe » Mon Sep 22, 2008 8:43 pm
johndoe1025 wrote:sounds like maybe a dodgy earth?
I've checked my battery cable running through the car to rule the positive out, that seems fine (battery in boot), but I didn't manage to check out the earth. I'll have a look at that a little later.
I'm starting to run out of ideas :\
Ex:
eViLoNe
Postby johndoe1025 » Mon Sep 22, 2008 8:45 pm
not just your battery earth, check for the various earths in the engine bay-youll see them around bolted to the body. also look for burned or melted terminals-sign of a crap connection. we had a RX7 at work today, rough running fault came up with two codes (air temp and speed sens) replaced one earth cable, prob gone
johndoe1025
Postby eViLoNe » Mon Sep 22, 2008 8:46 pm
johndoe1025 wrote:not just your battery earth, check for the various earths in the engine bay-youll see them around bolted to the body. also look for burned or melted terminals-sign of a crap connection. we had a RX7 at work today, rough running fault came up with two codes (air temp and speed sens) replaced one earth cable, prob gone
Alright cheers, I'll take a look at that shortly. I'll also check my codes too, just to see if it's throwing any up.
Ex:
eViLoNe
Postby johndoe1025 » Mon Sep 22, 2008 8:49 pm
yeah good idea, if its an intermittent fault and its coming with a sudden movement of the body, it should be a connection fault. maybe water in a plug even? thats caused me problems before
johndoe1025
Postby eViLoNe » Mon Sep 22, 2008 9:06 pm
johndoe1025 wrote:yeah good idea, if its an intermittent fault and its coming with a sudden movement of the body, it should be a connection fault. maybe water in a plug even? thats caused me problems before
Yeah, good point. I changed the radiator over recently, so I'll check its sensor and pipes.
Only error code being thrown up is 51, gunna search up on that shortly to figure out what it is.
Edit; Just checked out code 51, looks to be Switch Condition Circuit, which is related to A/C and also TPS, so there might lie my problem
Ex:
eViLoNe
Postby johndoe1025 » Mon Sep 22, 2008 9:11 pm
not even like a fan or aircon plug loose is it? lol
johndoe1025
Postby eViLoNe » Mon Sep 22, 2008 9:26 pm
johndoe1025 wrote:not even like a fan or aircon plug loose is it? lol
Hehe, unlikely. I'm betting on my TPS. Now I've just got to find out where it is in this bastard of a engine bay :D
Ex:
eViLoNe
Postby johndoe1025 » Mon Sep 22, 2008 10:03 pm
haha your out of my knowledge/advice region now. im just a humble apprentice :P
johndoe1025
Postby escortman » Mon Sep 22, 2008 10:17 pm
tps will be on the throttle body
4x4 toyota blizzard offroader
escortman
Postby eViLoNe » Mon Sep 22, 2008 10:43 pm
escortman wrote:tps will be on the throttle body
Yup, I found it after a lot of investigating in the dark :D.
I mucked around with the connection a bit, and the car seems to be running a lot better now, which is a bonus. I'll keep an eye on it though. Worst case scenario is a new TPS.
Ex:
eViLoNe
Postby johndoe1025 » Mon Sep 22, 2008 11:06 pm
was the plug algud?
EP82 GT-went mega hard for completely stock, 15.09 quarter, gone now :(
AE111 Levin BZG current! 4AGTE next? you never know....
johndoe1025
Postby eViLoNe » Mon Sep 22, 2008 11:11 pm
johndoe1025 wrote:was the plug algud?
Didn't look to bad. Didn't have a major look at it though, as it was dark outside, and I only had torch light.
I'm going to investigate further tomorrow night after work when it's still reasonably lit up.
Ex:
eViLoNe
Postby johndoe1025 » Mon Sep 22, 2008 11:12 pm
sweet just make sure it not corroded/burned/melted/broken/bung wires or anything
johndoe1025
Postby eViLoNe » Mon Sep 22, 2008 11:14 pm
Yeah, I'll be checking all that. I'll also be checking the battery cable from the boot, right up to the end point in the engine bay. I have a feeling that's causing me a wee bit of troubles also, who knows.
Ex:
eViLoNe
Postby johndoe1025 » Mon Sep 22, 2008 11:17 pm
ahh relocated battery? they can be a b**ch man
johndoe1025
Postby eViLoNe » Mon Sep 22, 2008 11:21 pm
Hehe, indeed. Was in the boot when I bought it. Haven't had a problem with it yet, but I'm still keen on checking it out for myself to make sure shit was done properly, :P, I'm a bit over anxious when it comes to things like that.
Ex:
eViLoNe
