Antifreeze in cylinders
Postby samlloyd » Mon Sep 22, 2008 6:21 pm
Sounds worse then it is,
If your familiar with an RB intake manifold, they also run water through them, when i was taking mine off, a bit of liquid ran into the motor :x Dried up all the liquid that was sitting on the valves, but naturally some of the valves were open.
Its not a lot of fluid but anyideas to get it out
Heatgun?
Sponge on a string and hope it doesnt fall off?
samlloyd
Postby gepsk8 » Mon Sep 22, 2008 6:30 pm
pull the plugs, with long nose air gun try blown all water out with rag over the top of it, then crank over with out the plugs, and repeat until the waters gone.
O272754663
gepsk8
Postby YeMs » Mon Sep 22, 2008 6:39 pm
gepsk8 wrote:pull the plugs, with long nose air gun try blown all water out with rag over the top of it, then crank over with out the plugs, and repeat until the waters gone.
something along those lines will be fine. it takes a whole cylinder full of water for it to hydraulic. just blow the excess out, chuck it all back together and fire it up. any excess moisture will be imediately evaporated.
Your local Hybrid Elite tech
YeMs
