3S Thermostat Housing
Postby nz_climber » Thu Sep 25, 2008 7:20 pm
Hi all..
Problem: the thermostat housing ony my beams 3sge - sticks out perpendicular (90 degrees) from the block and pointing slightly down. This puts it in the way of a lot of things. (since the engine is no longer in the orginal car)
option 1: Is there a thermostat housing from a another variant of the 3s engine or any toyota that will fit and point forward from the block? If so where can I get one?
option 2: Cut the existing housing and get it welded so it points out the front of the engine
comments please
aaron
nz_climber
Postby strx7 » Thu Sep 25, 2008 10:36 pm
what is the motor originally out of?
Postby Bling » Thu Sep 25, 2008 10:43 pm
Celica RA45 wrote:you can use a gen 3 which points to the front ,same as fwd beams
or the altezza 1 which has a droopy dcik and goes forward then goes 90%from that
moved from a new thread made by Celica RA45
Postby nz_climber » Fri Sep 26, 2008 12:42 pm
cheers for that. the orginal was an altezza one.
nz_climber
