New brakes!
New brakes!
Postby cat007 » Fri Sep 26, 2008 4:49 pm
WAHOO!
Picked up my Mintex 1166 pads from Race Brakes yesterday. Apparently these pads should even be able to stop 1650kg from 220kmph I'm told hahaha. Got nice fluid from them as well.
$367 later though - OUCH!
But hey - would cost more to hit the armco hehe
So - who's racing on the 4th? :)
Re: New brakes!
Postby barryogen » Fri Sep 26, 2008 6:21 pm
cat007 wrote:Apparently these pads should even be able to stop 1650kg from 220kmph I'm told hahaha.
Shouldn't most pads be able to do this... well, eventually anyway, maybe there is more to the description that just a weight and speed.
barryogen
2ZZ Guru in training
Re: New brakes!
Postby cat007 » Fri Sep 26, 2008 6:45 pm
Errr yes, but I want them to do it over and over. Regular pads and fluid would explode if you attempted that lol
Postby Leon » Fri Sep 26, 2008 7:24 pm
I had my 1166's glowing red, and smoke pouring out of the wheels after many many many many 100 to 10k stops as hard and fast as I could. Brakes still working strong.
Incidentally, that's the bedding in process and is highly amusing.
However ... lay in a stock of brake discs, and wheel cleaner.
You're going to be needing to wash your wheels every 100meters, and if you're racing much, and my car is anything to go by, you will get through at least three sets of front rotors during the life of the pads 8)
Postby Bazda » Fri Sep 26, 2008 7:47 pm
If you run those pads I would suggest running brake ducting!!!
I ran these pads, they are SOFT, my brakes got way to hot and that was 2 laps around Taupo. Smoking heaps, cracked the pads cos they got too hot.
I had previously run them in till brake fade on the road.
But just beware :)
Postby Leon » Fri Sep 26, 2008 9:08 pm
I think it must depend on the power of the car ... in my rather more standard car, I thrashed the living shit out of the brakes on Manfeild, and they worked perfectly all day every day without even the slightest hint of fade.
Postby method » Fri Sep 26, 2008 9:26 pm
You got to watch it with hot brakes, you can warp your rotors... not good
PICS UPDATED DAILY
method
Postby cat007 » Fri Sep 26, 2008 10:02 pm
wanna know whats NOT fun - almost finished with bleeding the brakes with nice new fluid - 2nd time round, last wheel - and you forget to check the master cylinder - and it sucks in air - :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
Postby strx7 » Fri Sep 26, 2008 10:53 pm
Bazda wrote:I ran these pads, they are SOFT,
I fine it a bit strange you say they are soft bazz. Everyone i know that runs them, probably close to a dozen people, say they eat brake rotors like they're going outta fashion. Now to me that says that the pads are very hard, harder than the disc, hence they eat the disc and the pads are very slow wearing.
Postby Bazda » Fri Sep 26, 2008 10:59 pm
They eat the pads cos they have alot of metal content in them.
They get alot of bite because of this.
you can tell the material in it is soft as the brake dust is crazy.
Dont get me wrong they are def a good pad :)
Remember you can get 2 types 1166 and 1144.
Re: New brakes!
Postby matt dunn » Fri Sep 26, 2008 11:18 pm
At Ruapuna? Or the North Island meeting?
Re: New brakes!
Postby cat007 » Fri Sep 26, 2008 11:25 pm
Puke - just an open/testing day
Postby Bazda » Fri Sep 26, 2008 11:37 pm
Gota Love puke.
nothing like those 200kph corners :D
Postby cat007 » Fri Sep 26, 2008 11:51 pm
Bazda wrote:Gota Love puke.
haha - they may be ok in a car that handles - not a tank lmao!
Postby molex » Sat Sep 27, 2008 3:15 am
Run mintex 1166 here, can *not* get them to go wrong. Have tried.
That said my car weighs pretty much exactly half yours :o
molex
Postby Scrunty » Sat Sep 27, 2008 4:19 am
Running Ferodo DS2(somethings ~$220 odd i think) in my aw11 up front, seem to be a pretty good balance for everyday driving and the odd track-day/club event.
Don't need any heat in them for stopping on the road straight off the bat.
Used with Penzoil Dot4 racing fluid ~$70/L (all from race-brakes)
Have not tried the mintex to compare but I am getting some fairly good milage out of these Ferodos I think... how many K's does everyone average with there XX pads. (And used how)
Be interested to know what sort of legs the mintex have.
/boy its time for bed
SW20 g4 n/a
Scrunty
Postby Leon » Sat Sep 27, 2008 7:47 am
the g/f had 1166's in her road car, and I think she got something like 50,000 out of them. But, that was road car use. My old club car got about four years on them, but I'm not sure how many km that amounted to.
Postby Bazda » Sat Sep 27, 2008 10:43 am
wow the must be making it from diff stuff, when my dad used them for racing they only lasted a few meets.
He also said as they got older they lost its grip and were use less lol.
So he then went to a ferodo DSXXXX and they worked the best he recons.
But not we dont use std type pads cos we upgraded to wilwoods etc and got MUCH better braking performance :D
Re: New brakes!
Postby soopachargen » Sat Sep 27, 2008 12:03 pm
cat007 wrote:. Apparently these pads should even be able to stop 1650kg from 220kmph I'm told hahaha.
sounds like they tested them in the v8 taxicars :P
When in doubt, down and out.
soopachargen
Postby postfach » Sat Sep 27, 2008 12:05 pm
They work fine on my car, but I bin them when they wear to approx half the original thickness, I found they just aren't as good after that point
postfach
