Floppy SW20 wing mirrors
Postby Adamal » Tue Sep 30, 2008 11:56 am
So I'm not sure if this is standard in all Japanese SW's, but mine has retractable mirrors which appear to have gone all floppy.
I've had a quick look at trying to tighten them up, but the screws on the bottom don't want to seem to 'tighten' up.
Rather than pull it apart, just thought I'd ask if anyone knows if you can replace anything inside, or if its just something I have to live with.
Cheers guys!
Postby touge rolla » Wed Oct 01, 2008 5:48 pm
Mine are floppy too.
Guess you've got to pull them apart, but bugger doing that.
touge rolla
Postby Heylin » Thu Oct 02, 2008 5:18 pm
Ditto got about 2-3 mm play on mine, quite sure its the plastic gears for the motorised retraction system, the gear teeth get worn over time and allow play.
The Mirrors themselves are easy to remove but then what ?.
If I had a spare $600 Id get some nice fixed Ganador M3 Style mirros.
Heylin
Heylin
Postby GDII » Thu Oct 02, 2008 7:40 pm
My mirrors flopped around so I removed the mirrors from the car and tightened the screws underneath.
The screws were already very tight but they were out about 1mm so they must be able to be tightened (a lot easier when they are off the car).
Now there is just the backwards and forwards movement of the motorized retraction system.
Can't do much about that but they don't vibrate anymore, so now when I use them I don't get a 'fuzzy' image.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby scottyj » Thu Oct 02, 2008 9:37 pm
My motors for my wing mirrors are broken :cry:.
1991 MR2 GT [Red] (Gone)
1991 MR2 GT [Green] (Gone)
1991 Starlet [Red] (Gone)
scottyj
Postby Snaps » Thu Oct 02, 2008 9:44 pm
My mirror housing is 'floppy' not my actual mirror, can the mirror be taken off from the front to get to some screws or something that could be behind it?
Cheers,
Brandon
2000 ZZT231 Manual Toyota Celica
Snaps
