3TGTE turbo upgrade
3TGTE turbo upgrade
Postby RS13 » Tue Sep 30, 2008 4:54 pm
Hi guys,
Carrying on from the other thread, we're looking to upgrade the standard turbo on a 3TGTE.
What we'd like to know;
What bolt-on options we have from other Toyotas (GT4, etc),
We've been told the standard ECU and airflow meter can handle considerable power, however the limiting factor is the injectors, what are our options for decent upgrades? If we were to fit larger injectors, what modifications would we need to do to the factory ECU?
Lastly, as we'd like to intercool the engine, without cutting any holes anywhere, we were looking at adapting perhaps a Subaru or GT4 water-to-air intercooler to fit. Has anyone had much luck with fitting these to other engines, and what's involved?
Cheers. :)
RS13
Postby Adydas » Tue Sep 30, 2008 5:36 pm
Blitz do a turbo kit ( as seen on my car ) ive gone hole hog but it might be possible to run less boost or a smaller unit from the same turbo kits ( based for ST205 but can easy fit )..
comes with adapter, oil drains and feeds etc i think.
As for IC i have a ST205 WTA for sale with Heat Exchanger im looking to move on now i know my other one dont leak etc and i dont need a spare.
The options are as wide as your pocket goes deep for options.. Weigh that up first then work on that ( plus about 35% in $$ saftey numbers for the hidden costs.)..
Adydas
Postby Boosted_162 » Tue Sep 30, 2008 6:09 pm
Adydas wrote:Blitz do a turbo kit ( as seen on my car ) ive gone hole hog but it might be possible to run less boost or a smaller unit from the same turbo kits ( based for ST205 but can easy fit )..
Cliff, i want that WTA! Ill talk to you online about it sometime, or tomorrow night meet if there is one?
Postby RS13 » Tue Sep 30, 2008 10:26 pm
You realise I said 3TGTE, not 3SGTE? How much are you looking at for to WTA?
RS13
Postby Adydas » Wed Oct 01, 2008 5:26 pm
HAHAH sorry, i just read it.. came home from a long day at work half awake..
Good luck on your quest..
Adydas
Postby RS13 » Wed Oct 01, 2008 6:03 pm
Adydas wrote:HAHAH sorry, i just read it.. came home from a long day at work half awake..
Lol, sweet as.
Not looking too easy at the moment anyway, such a large motor in a small car means very little room for larger anything!
RS13
