Auto 3S to manual
Auto 3S to manual
Postby RS13 » Fri Oct 03, 2008 4:26 pm
When putting a previously auto 3SGE into a manual car, what will I need to change over, or is it just flywheel and I'm away?
Cheers.
RS13
Postby Celica RA45 » Fri Oct 03, 2008 4:39 pm
fly wheel with manual fly wheel bolts and clutch and pressure plate etc
Celica RA45
Postby strx7 » Fri Oct 03, 2008 5:20 pm
You may strike it lucky and find it has the same bolt pattern crankshaft, if not you may have a headache trying to find a flywheel with the auto crank pattern
Postby RomanV » Fri Oct 03, 2008 8:51 pm
Yeah I've ran an auto motor in manual config, no probs with bolt pattern on crank shaft or whatever.
IIRC all 3SG(T)E's have the same 8 bolt PCD except for the gen 1, and I think the 3SFE/5SFE/etc have a smaller PCD, or 6 bolt to flywheel, or something making them different.
Postby RS13 » Fri Oct 03, 2008 9:32 pm
Awesome, thanks guys. So there isn't any extra idle control or anything on the inlet manifold? And I don't need to change the spigot bearing?
RS13
Postby RomanV » Sat Oct 04, 2008 2:25 am
There isnt a spigot bearing either way.
Postby strx7 » Sat Oct 04, 2008 9:09 am
3SGTE uses a slightly different PCD to 8 bolt 3SGE, 3SFE and 5SFE cranks.
in the 2nd gen 3SGE's there IS different crank patterns between auto and manual but not ALWAYS. Seems to be luck of the draw
Postby RomanV » Sat Oct 04, 2008 3:12 pm
I've had a 3SGTE flywheel bolted up to a 3SGE no probs...
Postby fivebob » Sat Oct 04, 2008 4:37 pm
RomanV wrote:I've had a 3SGTE flywheel bolted up to a 3SGE no probs...
Most 3S-G crankshafts, apart from early model ST162, ST165, ST171 & SV21s (which changed in the last months of production) are the same part #, including the Beams engine.
Engines from the following chassis codes all use 13411-74909 ( some are superceeded from 13411-74903 to this part#)
ST162 *8907-8908
ST165 *8907-8908
ST171 *8907-9202
ST182
ST185
ST195
ST202
ST205
ST206
ST215
ST216
SV21 *8907-9007
SV32
SV33
SW20
SXA10
SXA11
SXE10
Postby tex » Sun Oct 05, 2008 5:58 pm
As per above. I personally have not had any probs converting auto to manual in any 3SGE gen2 motor i have come across, and I have manual converted a few. I have come across some gen1 (normally FE motors) with different bolt pattern but other than that I thought they were all the same turbo and NA. Just that the turbos ran a bigger flywheel which is obvious.
tex
Postby fivebob » Sun Oct 05, 2008 6:51 pm
Yes, 3S-FE crankshafts are definitely different to 3S-G(T)E versions.
Postby RS13 » Mon Oct 06, 2008 8:17 pm
Also, best way to remove 3SGE? I'm aiming for taking the motor and box together out the top, I've seen people drop the engine out the bottom, But I've never done this, and I don't think the hoist could handle it!
Also, I've only got the PS pump to do, looks like its' gonna be a bastard, I wanted to keep the lines all together preferably. Am I going to have to disconnect it, or is it possible to reach up from underneath and undo it from the engine?
Any other tips or things to watch out for?
Cheers.
RS13
