Fuel questions
Fuel questions
Postby samlloyd » Mon Oct 06, 2008 8:14 pm
Whats the story with adjustable fuel pressure regulators and do i need one?
Currently just have a walbro pump with evo 510cc injectors in my RB, what sort of pressure do these pumps put out, and if theres more pressure in the fuel rail I imagine that theres going to be more fuel in the cylinder when the chamber opens?
Im not having any fueling issues at the moment, but looking at areas to upgrade.
And how do i find out how much KW 6x510cc injectors will support?
samlloyd
Postby Adydas » Mon Oct 06, 2008 8:21 pm
510cc wont go a million miles to far, If you were having issues with fueling i think youd know by now =D
Take your tuners advice, My tuner knew hed need it and just installed it.. If he didnt he wouldnt..
Used this post to move this tech question to a more suitable area
Adydas
Postby Akane » Mon Oct 06, 2008 8:33 pm
Adjustable FPR is one way of getting more out of your injectors. you'll also need it if you run crazy PSI as there is a SLIGHT effect of the boost pushing / working against the fuel coming out of the injectors.
550cc x 4 = 2200cc makes 320hp @ ~40psi, so 510 x 6 = 3060, my wild guesstimate will say it's good for 450+ at around 40psi.
Or you could just use this injector calculator as Akane is famous for talking trash http://www.rceng.com/technical.aspx
Postby samlloyd » Mon Oct 06, 2008 8:39 pm
Wont need to go a million miles, fuel isnt whats halting power. Its the turbo at this stage.
Would one day like to get 300rwkw, just wondering if 510s would do it?
samlloyd
Postby escortman » Mon Oct 06, 2008 8:49 pm
510s should give plenty in a rb20 stil gota member theyr only 2lt, mates rb30det with t3t4, 7m 440ccs on 12psi got 280kw injectors didnt have heaps left but turbo ran out f puff at 4500 rpm ha
4x4 toyota blizzard offroader
escortman
Postby samlloyd » Mon Oct 06, 2008 9:31 pm
(it is a rb30det)
samlloyd
Postby postfach » Mon Oct 06, 2008 9:45 pm
I think for a safe margin you would want to use 650cc+ injectors for that much power.
postfach
Postby escortman » Mon Oct 06, 2008 9:48 pm
smithers wrote:(it is a rb30det)
ahh then u maybe want a little bigger, he was going to run i think sard 650s or so with t70 turbo,
escortman
Postby matt dunn » Mon Oct 06, 2008 10:27 pm
approximate rule for a 6 cyl is inj size = hp,
so 510cc injectors are good for 510hp on std pressure.
Postby postfach » Mon Oct 06, 2008 10:33 pm
matt dunn wrote:approximate rule for a 6 cyl is inj size = hp,
At the flywheel yes? That means they would reach 100% duty cycle at 320ishrwkw assuming 15% loss through the transmission+diff, and that would be best case scenario IMO.
If it were my car I would want a bigger "buffer"
postfach
Postby tsoob » Tue Oct 07, 2008 9:26 am
postfach wrote:I think for a safe margin you would want to use 650cc+ injectors for that much power.
+1
510 will be ok up till about 280KW
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby MAGN1T » Wed Oct 08, 2008 9:19 pm
Me, I'd never take any tuners advice.
If you turn up the fuel pressure, it gives you more fuel at the top end.
It also gives you too much fuel at the bottom end and the ECU can't compensate properly..
Then people start threads like "why does my car use too much fuel".
The less you change, the less chance you've got of screwing everything up.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby escortman » Wed Oct 08, 2008 9:45 pm
why wouldnt u take a tuners advice?
and im running slightly higher fuel press and my cars fine
fuel compsumption depends more on tune plus if he was worried about using heaps of gas hed prbly be driving a starlet
escortman
Postby MAGN1T » Wed Oct 08, 2008 10:33 pm
escortman wrote:why wouldnt u take a tuners advice?
From a total pricks point of view,
I've ben playing wit turbos for well over 25 years, modding cars for over 30 years.......... every "tuner " out there is only concerned with what's in my wallet..... they want it.........They think they know more than me....... just because to me it's only a hobby and I don't usually get my hands dirty.
My business is electronics.... going back....... building custom electronics for cars. Before computers existed.
Go figure?
Steve
MAGN1T
Postby matt dunn » Wed Oct 08, 2008 10:50 pm
MAGN1T wrote:Me, I'd never take any tuners advice.
If you are trying to tune a car only by using the adjustable pressure reg,
which is a dumb idea.
An adjustable FPR is only any good in conjunction with a tuneable ECU,
and then they can help if your injectors are close to max,
or it can give you a slightly better safety margin for injector duty cycle.
and depends on who your tuner is and how well you know them.
If you dont trust your tuner you may as well DIY.
I trust the guys who tune my car,
but when they tell me it would be better with this or that they also explain why,
Postby MAGN1T » Wed Oct 08, 2008 10:59 pm
matt dunn wrote:I trust the guys who tune my car,
I tune my own cars.
On the road.
With NB oxy sensor.
And custom knock detector.
A lot easier than using the likes of a Gunsons colourtune (for multiple carbs) and a lot easer than doing plug cuts after a top end shut off.(did someone say "turbotimer?)
Once you "hear " knock, it's too late.
Really the V8 guys are still way ahead on tuning, in a lot of ways, they don't rely on computers.
Dynos only exist to rape your wallet and produce a fancy printout.
Steve
MAGN1T
Postby 4agtepwr » Wed Oct 08, 2008 11:15 pm
:roll:
How do you get a correct a/f reading with a narrow band o2 sensor because correct me if im wrong but an nb o2 sensor is very accurate
at 14.7 or stoich but not very good above or below that hence narrow band not wide band. How do you know when the engine is developing peak torque and your actully getting gains from the igniton timing your putting in? Dynos are a very useful tuning tool, not just for a fancy print out. And safer than road tuning to say the least.
Sorry to go off topic
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby matt dunn » Wed Oct 08, 2008 11:26 pm
I too have tuned cars,
also with a narrow nand O2 sensor,
and on the road, (race track actually but same stuff)
was about 5 years ago, and the car still runs great,
compete's in a lot of events, and they guy is quite happy with it.
but I have no doubt if it went to a better tuner with a dyno,
it would come back with more power, use less fuel ,
and do quicker lap times.
you must have a very sensitive butt to be able to get the best out of a car on a road tune.
Postby MAGN1T » Wed Oct 08, 2008 11:35 pm
The best dyno tune is never the best track tune.
The best track tune is never the best dyno tune.
That's because the conditions are never the same.
Just think about it.
All the drag cars would go out on the track after a dyno and do their PBs.
It never happens.
The butt doesn't come into it ....about .86v on a good NB...... not a cheap charlie crap NB but a proper factory one...... they're not the same.
Steve
MAGN1T
Postby mister2 » Thu Oct 09, 2008 11:41 am
Rough rule of thumb for injector sizing:
200hp per L/min of flow, so 6x510cc = 3L/min = roughly 600hp.
Your Walbro will flow around about 3.2L/min on boost so these injectors will be pretty good for that (from memory, check the flow maps of the pump), so going for more flow from a adjustable FPR may be a waste of time anyway.
Flow goes up with the square root of the pressure too (eg, double the pressure and you only get sqrt(2)=1.4x the flow) so only really worthwhile if you were right at the limit of your injectors and wanted a touch more.
Also, we get a lot of people to remove their adjustable FPR's and go back to their factory one which works a lot better in most cases (cheap FPR's are terrible).
Haha righto. Partly agree though that you may see differences in tune (ram air effects etc) which is why we will go out and check at the track if required. However there is absolutely no substitute for the flexibility or repeatability of a top dyno with excellent datalogging equipment.
If you want to be measuring AFR, NB is a waste of time. With how cheap Innovate Wideband gear is, it staggers me when people don't use it.
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
