smithers wrote:(it is a rb30det)
matt dunn wrote:approximate rule for a 6 cyl is inj size = hp,
so 510cc injectors are good for 510hp on std pressure.
postfach wrote:I think for a safe margin you would want to use 650cc+ injectors for that much power.
escortman wrote:why wouldnt u take a tuners advice?
MAGN1T wrote:Me, I'd never take any tuners advice.
If you turn up the fuel pressure, it gives you more fuel at the top end.
It also gives you too much fuel at the bottom end and the ECU can't compensate properly..
matt dunn wrote:I trust the guys who tune my car,
Haha righto. Partly agree though that you may see differences in tune (ram air effects etc) which is why we will go out and check at the track if required. However there is absolutely no substitute for the flexibility or repeatability of a top dyno with excellent datalogging equipment.The best dyno tune is never the best track tune
