Replacing K50 with T50 in AE85
Postby Stealer Of Souls » Tue Oct 07, 2008 10:18 am
Ok...
I've just spent the last hour trawling the forums and I can't find the answers I'm looking for.
Basically, my latest K50 has died. And I've decided it's high time I got my T50 into my car.
It is an AE85 with 4AGE and T series rear end.
I have the T50 with A series bellhousing (fingers crossed it's actually a 22 spline as was advertised... Dumby didn't check when he bought it), clutch fork, hydraulic clutch pedal, master and slave cylinders.
I need to sort out clutch lines, gearbox crossmember and driveshaft.
What I would like to know is...
Can I use my K50 gearbox crossmember in any way for the change?
Is my existing one piece AE85 driveshaft of any use?
I realise the easiest way would be to get the proper bits, but I just can't seem to find any without having to sell a kidney.
'86 AE85.5 Levin
Stealer Of Souls
Postby fangsport » Tue Oct 07, 2008 8:55 pm
existing driveshaft will only work if you have purchased a 20-spline T-50.
TT14# corona driveshaft bolt up or find a 22-spline yoke and get it welded to existing.
fangsport
Postby Mr Revhead » Tue Oct 07, 2008 10:10 pm
i've got a 22 spline driveshaft for sale...
Postby Xyrath 86 » Tue Oct 07, 2008 10:25 pm
k50 crossmember works fine, just need to slot/redrill some holes.
Xyrath 86
Postby Stealer Of Souls » Wed Oct 08, 2008 12:01 pm
Choice on the crossmember.. that's one thing I can cross off the list..
Mr Revhead... how much you after (including getting it to Auckland)?
'86 AE85.5 Levin
Stealer Of Souls
Postby RollaGT_87 » Thu Oct 09, 2008 4:34 am
Sell a kidney and do it properly? You only need 1.
Tip for successfull rally driving: Don't sink you're car in the first pond to catch your eye.
"That's a f**kin' b*gg*r innit??"
"We were a bit hot, thought we'd take a dip n cool off"
RollaGT_87
Postby Stealer Of Souls » Thu Oct 09, 2008 11:46 am
hahaha.. true...
Nah. I'm not interested in dodgy, but would like to recycle where possible...
I don't mind paying the price to do it right, as long as the price is reasonable. E.G. I wouldn't pay $250 for a K50.. that's robbery...
'86 AE85.5 Levin
Stealer Of Souls
Postby shihad » Fri Oct 10, 2008 1:15 am
i sold my k50 4 250 including delivery they still haven't caught me.
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby Stealer Of Souls » Fri Oct 10, 2008 9:22 am
Such robbery..
I paid $50 each for the two I killed... and had a spare from a donor car... until I had to sell the car...
'86 AE85.5 Levin
Stealer Of Souls
Postby Stealer Of Souls » Thu Nov 06, 2008 9:48 am
Hmmm...
Sooo... According to my WOF guy, if I have to modify the crossmember to fit the box, then I should have a Cert for it....
Can anyone confirm that both he and I are thinking of the same thing.... At this stage I don't want any hassles with WOFs, and this guy knows my car, and all the mods that have been done to it. So basically I don't get hassles from retarded VTNZ people who don't really know the rulebook.
And on another note, if anyone has a AE86/T50 gearbox crossmember, could they possibly take a pic and do some measurements for all the bolt holes...
I have a sneaking suspicion that I have a crossmember sitting in my pile of bits... only problem is I have no idea if it's a AE85/K50 or AE86/T50 crossmember...
Lastly, speedo drive for K50 Vs T50.... are they the same ratio?
'86 AE85.5 Levin
Stealer Of Souls
Postby GDII » Thu Nov 06, 2008 11:12 am
Yes you need a cert for the modified crossmember.
If you cut, weld, or heat the crossmember and modify its shape from factory you need cert.
Check the LVVTA website under Engine and Drivetrain conversions, Section 2, 2.4
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby rollaholic » Thu Nov 06, 2008 11:39 am
its not like you arent supposed to have a cert for the 4age...
Postby Stealer Of Souls » Thu Nov 06, 2008 2:57 pm
Everything else is already certed...
I don't wanna pay $400 just to cert a crossmember when I can potentially buy one that fits...
So what about drilling new points/slotting original bolt holes.. I would assume that that counts as modification..... Supposedly that's all I need to do...
'86 AE85.5 Levin
Stealer Of Souls
Postby Xyrath 86 » Thu Nov 06, 2008 5:48 pm
Need to redrill the holes in the middle cos k50 ones are too far apart. If you welded up the old holes, grinded them flat and painted them no one could tell its modified.
The 2 outter holes just need slight slotting, can't even tell.
Its pretty straight forward.
Xyrath 86
Postby Stealer Of Souls » Thu Nov 06, 2008 11:09 pm
Cheers man. I might have a chat to "the man" he might be able to sort me out without alerting the boss... lol...
But seriously, that's good. Pretty straight forward.... I'm having to get my usual garage to do it for me because I don't currently have the space (or time) to deal with it myself.... I'll talk to him and see what he says...
Thanks again for the info.
'86 AE85.5 Levin
Stealer Of Souls
Postby Stealer Of Souls » Fri Nov 07, 2008 7:06 am
anyone happen to have a pic of an ae86 one?
'86 AE85.5 Levin
Stealer Of Souls
Postby Xyrath 86 » Fri Nov 07, 2008 10:59 am
Not a great pic but I didn't feel like jacking the car cup :P. A bit different then the 85 one, 2 bolts at each end to bolt to the chassis and a slot for the speedo cable to go through.
Xyrath 86
Postby d1 mule » Fri Nov 07, 2008 5:42 pm
i can get a betta pic if you reall want man???? ill be workin on the car tomorro anyway
d1 mule
Postby Stealer Of Souls » Mon Nov 10, 2008 9:18 am
Cool.
Looks like I'm in luck.. I had a crossmember floating around in the unlabelled box of unlabelled bits...
:oops:
Guess I didn't need one after all that...
Thanks for the help guys.
'86 AE85.5 Levin
Stealer Of Souls
Postby Stealer Of Souls » Fri Nov 28, 2008 11:55 am
Hmmm.. new development... Well new question.
Speedo cable.. what did everyone do? Is there an extension piece for the AE85 cable? or are they different?
'86 AE85.5 Levin
Stealer Of Souls
