Anyone built a shiftlight?
Postby 85AW20v » Thu Oct 16, 2008 10:13 pm
It would be good to have one in the racecar so I don't keep hitting the limiter especially off the start. Would be good to have 2 stages to it, one LED coming on 3-400 revs before the other.
It's an ST 20v in the AW if that makes any difference. And I don't know anything about electronics but can follow instructions..... :?
See ya
Simon
85 MR2 20v
85AW20v
Postby MrOizo » Thu Oct 16, 2008 10:30 pm
Jaycar does a pretty good kit.
I borrowed one off gadget for a while... was a 3 stage one - all lights were set-able
Cant seem to find it at the moment though :/
heres one but not the one
http://jaycar.co.nz/productView.asp?ID= ... &SUBCATID=
MrOizo
Toyspeed Legend
Postby Distrb » Thu Oct 16, 2008 10:36 pm
i built the one Oizo is talking about from jaycar, was the 'Rev Limiter/Gear Shift Indicator Kit' IIRC. I Used superbright LED's instead of the incandescant globes the pack comes with. takes a couple of hours soldering all the bits together
Neo also runs the same kit in his race car. Silvertop powered.
Distrb
Regular Poster
Postby neo » Thu Oct 16, 2008 11:16 pm
not to mention another kit in the road car as well :)
Shift light kits in plastic lunch boxes FTW
Only issue I find with this is if you accelerate fast thee lights come on earlier than they would if you accelerate slower (100 - 400 rpm faster if you in neutral reving the engine)
So you really need to set it as you drive down the road.
I cant find the right kit, seems to be discontinued
Could use http://jaycar.co.nz/productView.asp?ID=KC5378&CATID=&keywords=&SPECIAL=&form=KEYWORD&ProdCodeOnly=yes&Keyword1=K&Keyword2=K&pageNumber=&priceMin=&priceMax=&SUBCATID=
neo
Postby ChaosAD » Fri Oct 17, 2008 7:25 am
I could sell you a megasquirt with a 3 stage shiftlight option :)
ChaosAD
Postby Bazda » Fri Oct 17, 2008 4:42 pm
or you could buy a gizzmo shift light.
autometer also make a shift light as well.
Postby Bradles » Fri Oct 17, 2008 4:58 pm
theres plenty around.. i think for mine, i ended up dismantling a monster tacho, that came with a shiftlight, and using the shiflight assembly out of that.
the only reason i went to that much effort though, was because i got the tacho cheap as.
Bradles
