white residue on brake pads
Postby cat007 » Fri Oct 17, 2008 3:52 pm
Hey.
Does anyone know what this white residue is? pads are Mintex 1166's
Postby barryogen » Fri Oct 17, 2008 4:18 pm
salted roads? or whatever that other stuff is that they use these days.
barryogen
2ZZ Guru in training
Postby cat007 » Fri Oct 17, 2008 4:21 pm
barryogen wrote:salted roads? or whatever that other stuff is that they use these days.
Only used for to drive to Pukekohe from the North Shore, few laps, then home.....
Postby johndoe1025 » Fri Oct 17, 2008 4:24 pm
to me looks like some form of corrosion or mayyyyyybe crap off your discs? (harder pads=more disc wear) but thats all i can think of. im no expert
EP82 GT-went mega hard for completely stock, 15.09 quarter, gone now :(
AE111 Levin BZG current! 4AGTE next? you never know....
johndoe1025
Postby 1I1 » Fri Oct 17, 2008 4:50 pm
probably completely wrong but maybe due to heat? (ie pads burning?)
TRD Clicky >>Here
1I1
Postby cat007 » Fri Oct 17, 2008 4:53 pm
1I1 wrote:probably completely wrong but maybe due to heat? (ie pads burning?)
I wonder if you are correct :(
I could smell them once after a hard stop into the hairpin - but the other times I couldn't
Postby 85AW20v » Fri Oct 17, 2008 4:54 pm
Looks like it's heat related but send the photo's or take the pads into Race Brakes, they should be able to tell you.
See ya
Simon
85 MR2 20v
85AW20v
Postby KinLoud » Fri Oct 17, 2008 5:13 pm
The binder solvent (or something) boils out of the pads during the early heavy brake applications - this is called "bedding in".
My guess is that the white powder is the result of the bedding in.
I remember seeing this once on my mintex pads ages ago - it was quickly hidden by all the brake dust!
Ken
Auck
021 408 863
Postby cat007 » Sat Oct 18, 2008 4:29 pm
As quoted from an email from the guys at Race Brakes regarding conditioning pads:
"A powdery gray area will become visible on the edge of the pad (actually the edge of the friction material in contact with the disc - not the backing plate) where the paint and resins of the pad are burning off. When the gray area on the edges of the pads are about 1/8" deep, the pad is bedded.
For a race pad, typically four 80mph to 5 and two 100mph to 5, depending on the pad, will also be necessary to raise the system temperatures during break-in to the range that the pad material was designed to operate at. Hence, the higher temperature material can establish its layer completely and uniformly on the disc surface."
Interesting....
