Changing blacktop waterpump
Postby Voyeur » Sat Oct 18, 2008 10:25 am
Hey guys,
Can a waterpump be changed without disturbing the cam belt? or do i need to take the belt off as well. Pumps died and i want to get it done this weekend
2005 vz ss commodore
Voyeur
Postby Bling » Sat Oct 18, 2008 1:02 pm
According to the blacktop manual, no, it says to remove it. Just what i read, haven't done it myself.
Postby Lloyd » Sat Oct 18, 2008 1:26 pm
Belt off
Postby Voyeur » Sat Oct 18, 2008 2:38 pm
Cheers guys, all done, what a sod of a job. and there definately was no way with the belt on. Oh well all set for next weekend
Voyeur
Postby ke25sr » Tue Oct 21, 2008 10:22 am
I changed the water pump about 2 months back. I didnt take the belt off. I wonder how the hell i done that.
ke25sr
Postby Voyeur » Tue Oct 21, 2008 10:53 am
I suppose it may be possible if you remove the stud at the top of the pump, instead of just the nut, but then you have the bolt behind the cam belt idler.
Voyeur
Postby ke25sr » Tue Oct 21, 2008 11:12 am
I just remember it was a prick of a job.
ke25sr
Postby AE25 » Thu Oct 23, 2008 11:43 am
if you remove alternator, remove water hose off back of water pump backing plate, undo the backing plate too and and slide the pump and backing plate out sideways.. does it come out easy? (whilst bending the backing plate water diffuser tab that sticks into the block?)
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby Voyeur » Thu Oct 23, 2008 11:59 am
NO
Voyeur
