any tricks for removing cam belt pulley from crank?
Postby AE25 » Sun Oct 19, 2008 5:20 pm
this not usually a problem but this one in particular is proving to be a real bitch of a thing.
on a silvertop 20v 4age. cant get woodruff key out, and pulley wont budge either.
anyone got any tricks to removing them?
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby Lloyd » Sun Oct 19, 2008 6:26 pm
Smash off the backing bit on it and get a puller in behind. I need a replacement one :(
Postby mjrstar » Sun Oct 19, 2008 6:52 pm
no jacking screws on the pulley then i take it?
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Lloyd » Sun Oct 19, 2008 6:56 pm
Nah, they're a bitch when they get stuck on those
Postby AE25 » Sun Oct 19, 2008 8:25 pm
got it off eventually. just have to be a bit brutal with a couple flat headed screw drivers between the oil pump housing and pulley. shock loading does the trick rather than constant pressure.
no jacking screws unfortunately and not enough room for a pulley puller.
should probably replace the pulley now as the lip is pretty munted :(
E2 & E7 fanatic
AE25
Postby matt dunn » Sun Oct 19, 2008 9:03 pm
Removed mine from my 1600 motor last week.
Had been on there ever since I owned the car.
CRC and a claw hammer used as a lever did the trick,
pull on the area where the keyway is,
and managed to get it off with no damage.
Postby TRD_ZERO » Sun Oct 19, 2008 10:20 pm
YEah i tapped mine off quite gently with a hammer and it just came off but then realised i munted the pulley.
TRD_ZERO
