5k rebuild.
5k rebuild.
Postby Infinite » Sun Oct 19, 2008 11:15 pm
has anyone here built a 5k? from search nothing comes up :S. i have a reground kelford cam with all the specs and piston's from a high comp race engine sitting here and would just like some info on what others have done.
Lots
Infinite
Postby matt dunn » Mon Oct 20, 2008 12:01 am
When I had a play with one back when I had a starlet,
I found the 5K I had, was a hydraulic lifter type, and so couldn't get anything but a std cam to run in it, and gave up on the idea.
But I have seen some info somwhere on converting them to solid lifters like a 4k etc etc.
Postby Dell'Orto » Mon Oct 20, 2008 1:27 pm
They're pretty basic motors, the biggest issue you'll have is the hydraulic lifters, but I believe you can still buy solid ones new from Toyota.
You'll want to get a non twinsquish head unless thats what those pistons were made for, otherwise you'll be wanting to run it on diesel :lol:
Also dont buy into the hype of 3K bigport heads, they're nothing flash. Or the 3K-B twin carbs either, they're no good. You'll want a pair of side drafts to take full advantage of the bigger cam.
Postby AE25 » Thu Oct 23, 2008 12:16 pm
you will find alot more information on http://www.club-k.co.nz
if using a race cam then the 'NZ new' km36 5k is the way to go. these have solid lifters instead of the hydraulic ones. otherwise theres a FAQ on club-k on how to use landcruiser lifters and 4k-u pushrods i think?
upgrading cam, compression, carby and valve springs will wake the engine up.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
