5k rebuild.
5k rebuild.
Postby Infinite » Sun Oct 19, 2008 11:15 pm
has anyone here built a 5k? from search nothing comes up :S. i have a reground kelford cam with all the specs and piston's from a high comp race engine sitting here and would just like some info on what others have done.
Lots
Infinite
Postby matt dunn » Mon Oct 20, 2008 12:01 am
When I had a play with one back when I had a starlet,
I found the 5K I had, was a hydraulic lifter type, and so couldn't get anything but a std cam to run in it, and gave up on the idea.
But I have seen some info somwhere on converting them to solid lifters like a 4k etc etc.
Postby Dell'Orto » Mon Oct 20, 2008 1:27 pm
They're pretty basic motors, the biggest issue you'll have is the hydraulic lifters, but I believe you can still buy solid ones new from Toyota.
You'll want to get a non twinsquish head unless thats what those pistons were made for, otherwise you'll be wanting to run it on diesel :lol:
Also dont buy into the hype of 3K bigport heads, they're nothing flash. Or the 3K-B twin carbs either, they're no good. You'll want a pair of side drafts to take full advantage of the bigger cam.
Postby AE25 » Thu Oct 23, 2008 12:16 pm
you will find alot more information on http://www.club-k.co.nz
if using a race cam then the 'NZ new' km36 5k is the way to go. these have solid lifters instead of the hydraulic ones. otherwise theres a FAQ on club-k on how to use landcruiser lifters and 4k-u pushrods i think?
upgrading cam, compression, carby and valve springs will wake the engine up.
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
