GTZ Supercharger cut out randomly
Postby .:O4AGTZ:. » Mon Oct 27, 2008 9:37 am
Well yesterday i had jsut left home probably got about 5km down the road and the car jerked a little and the engine check light had came on. Boost gauge showed supercharger obviously not working and was real jerky and gutless without it. Funny thing is tho, i turned around and went straight home, fired it up a few hours later and it all appeared fine. anyone think of any reasons? maybe something to do with the magnetic clutch on the supercharger maybe? car is due for a service, not overly due but definately due lol. will be doin that hopefully next week
.:O4AGTZ:.
Postby Lloyd » Mon Oct 27, 2008 9:58 am
Gone into limp mode. Check fault codes and see if there is anything in there. More than likely a fault with something else causing the ECU to go into protection rather than a fault with the supercharger
Postby .:O4AGTZ:. » Mon Oct 27, 2008 12:47 pm
oh ok. problem is that when i started it back up th engine light didnt come on at all and it was running all fine. so can i only check it when it happens?
.:O4AGTZ:.
Postby themaleman » Mon Oct 27, 2008 1:02 pm
try tighten your knocksensor
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby .:O4AGTZ:. » Mon Oct 27, 2008 1:25 pm
where abouts is the knock sensor located? from what i have herd if that is screwed up it can really do some damage. [/quote]
.:O4AGTZ:.
Postby rollaholic » Mon Oct 27, 2008 4:03 pm
forget about the knock sensor till you've checked the codes
Postby .:O4AGTZ:. » Tue Oct 28, 2008 7:22 am
it wont throw up any codes until until it hits limp mode again will it? cos if its sitting there now idling up to temperature nothing is wrong it, so i guess i have to wait till it happens again and do it then right?
.:O4AGTZ:.
Postby gepsk8 » Tue Oct 28, 2008 10:54 am
pm if u cant fix, can do it as perky
O272754663
gepsk8
Postby KinLoud » Wed Oct 29, 2008 7:06 am
Sounds a bit like a prob I had with my AE101GTZ...
It would sometimes run ok but othertimes jerk and splutter
I ended up replacing the computer - I understand they can have a similar prob to the silvertop computers where the capacitors fail.
It wouldn't show any codes at all when you jumped the diagnostic pins.
Ken
Auck
021 408 863
Postby Crucible » Wed Oct 29, 2008 9:56 pm
Id just bridge terminals and check it anyway, ecu may have stored it?
I have had to replace a couple of AE101 gtz ecus, they do play up!, not saying thats the problem in you're case, may well be a sensor also eh!.
Crucible
Real Life Mechanic
Postby TRD_ZERO » Wed Oct 29, 2008 10:12 pm
I have a similar problem with mine every now and again mostly under load it splutters and jerks around then i just back off the accelerator then put my foot down again and its fine. I checked the codes and the only fault was speed sensor.
TRD_ZERO
Postby themaleman » Wed Oct 29, 2008 10:34 pm
knocksensor is located under the intake, on the gearbox end. my car did what u describe, and was me knocksensor not screwed in probly (was only hand tight)
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Crampy » Thu Oct 30, 2008 4:24 am
I had a problem with my S/C AW11. Ended up being the S/C relay.
Got that sorted and away she went.
Crampy
Postby .:O4AGTZ:. » Thu Oct 30, 2008 8:37 pm
hmm yea sounds like it could be many things. took it out for a drive again today and nothing bad happened at all. could it just be a once in every ages sort of thing? ill bridge the terminals and see if it throws anything up tho
.:O4AGTZ:.
