Are they all the same ? between facelist and pre facelift ?
Obviously there is different ratios and LSD/Not LCD.
rollaholic wrote:ah i see what you are saying. when you say diff head most people think you are referring to the actual LSD itself, when you are actually meaning the carrier.
to the best of my knowledge, the carriers are all the same.
AE25 wrote:to me the carrier is the part the crown wheel bolts onto with the spider gears or lsd inside. the head is the complete unit that bolts into the diff housing.
there are variations to the diff head casting. some have a longer stud, usually for the taller ratios like 3.9:1. but swap the longer stud with the head and it'll swap across.
Mr Revhead wrote:the 4.77 ratios sold by palmside are toyota genuine ones...
have you tired contacting the forum sponsor?
