how long for fuel to evaporate?
Postby flygt4 » Thu Oct 30, 2008 9:16 pm
so...
attempting to drain a tank full of flat fuel from the tank via the fuel feed as toyota didnt see fit to put a drain bung on ae101 (not that i can find). had a blonde moment and neglected to block the other side of the fuel line to pressurise it . have dumped about 5 seconds worth of priming out the open return onto the back of the block.
how long until its safe to crank her over again? :lol:
flygt4
Postby l1ttle_d3vil » Thu Oct 30, 2008 9:23 pm
aslong as its not still damp and you can't smell much vapour, should be fine. i've sprayed fuel all over my engine from a leak on the fuel rail before, just blew it over with the airgun to and started it up fine.
but have a fire extuingisher handy just incase... :lol:
Postby flygt4 » Thu Oct 30, 2008 9:34 pm
lol going to abandon work for tonight anyway, car is pretty much sold so don't want to burn it down now.
can smell vapour very strongly :lol: its right by the starter motor and pulleys too so plenty of chance to spark.
i'd just found why it wouldn't start too so mighta had it running tonight after a 6 month hibernation :x
flygt4
Postby matt dunn » Thu Oct 30, 2008 10:39 pm
which was??
Postby flygt4 » Fri Oct 31, 2008 6:57 am
fuel pump relay is mounted to the battery behind the rear seat, the spade connector for the control wire had come loose :roll:
it really hard to find motivation during the winter months or i would have found it a lot earlier, took me all of 5 minutes to find as soon as i heard it wasnt priming.
flygt4
Postby rollaholic » Fri Oct 31, 2008 7:18 am
should be okay if you leave over night in a well ventilated area, as the fumes are the dangerous part. might pay to pour some water over affected area too
9 times outta 10 you would be fine but pays to be cautious with something as volatile as petrol vapour
