AE100R vs AE101
AE100R vs AE101
Postby metric » Sat Nov 01, 2008 9:33 am
Im now looking into converting my wagon from 4afe to 4agze.
Im looking at a ae101 gtz as a donor as there pretty cheap at the moment, but what i really want to know is if the actual subframes are the same.
I have read on here that the rears compatable so the discs will go on the back instead of the drums, however all the front area i have no idea?
Whats the easiest way to achieve this?
Also is the wiring harness interchangable at the ecu?
(changing fuel pump anyway)
would anyone be interested in a GTZ shell or even a 4afe powered GTZ? hahha hah aha
metric
Postby 20v_rollaboy » Sat Nov 01, 2008 8:45 pm
Has the GTZ got Super Strut Suspension?
If it does then Id suggest leaving your wagon's suspension in it, as the SS tends to crap out and is expensive to fix.
Engine wise, the 4agze will bolt straight in.
Wiring wise, If you are leaving the 4agze standard, use the standard ecu and splice the 4afe interior ecu loom in the 4agze loom.
Hope this helps :D
20v_rollaboy
Postby metric » Sun Nov 02, 2008 9:45 am
yeah thanks 20v_rollaboy
Didnt think about the superstrut idea will have a look tonight
Am i right in saying the bonnet wont close with the standard top mount?
metric
Postby 20v_rollaboy » Sun Nov 02, 2008 12:47 pm
Im not sure to be honest. When my wagon had a 4agze in it, it had a front mount.
If you're worried about it hitting the bonnet, I have a fiberglass bonnet with a scoop molded into it, for any 100 series Corolla. Willing to sell if you would like it.
20v_rollaboy
Postby metric » Sun Nov 02, 2008 3:55 pm
nah im probably gonna go more sleepa , will either go front mount or w2a anyway. but thanks
metric
