turbos for a 4k
turbos for a 4k
Postby bacon » Thu Nov 13, 2008 8:27 pm
just wanting to know wat type of turbo would suit a 4k? cheers.
bacon
Postby Dell'Orto » Thu Nov 13, 2008 8:32 pm
This is more of a tech question than a FS one ;)
Postby Lloyd » Thu Nov 13, 2008 9:51 pm
Have had a TD04 off a GSR, and a T25 from a CA18. Both on 5Ks though and were reasonably well matched. Probably about the easiest to find. If you're wanting it for a 4K then you'd probably be looking at something more like a 4E-FTE turbo from a GT Starlet
Postby drftnmaz » Tue Nov 18, 2008 2:56 pm
i used to run a vf10 off a subie but there abit on the large side... try a vj20 of a mazda gtx or a vj6 of the 86 mazda (B6T) 323's, should be cheap as to find because everyone upgrades to the vf10 (they fit in the same housing)
drftnmaz
