by Lloyd » Sat Nov 15, 2008 11:14 pm
Just paint it with the engine paint, high temp stuff. As long as the block is clean and dry you shouldn't have issues.
As for the frost plugs, just a little bit of ordinary sealant or a bit of loctite type stuff is fine. The plugs are soft enough that they should seal properly with nothing on anyway
