sump prep for new engine?
Postby deaf_rattle » Sun Nov 23, 2008 8:03 pm
I have had my sump hot tanked, but wondering what to do with it now.
I have thought about getting it winged and baffled, but ill probably hold off that for now and get that sorted later.
what should i do to the surface of the sump? i will need to get it hot tanked again as it has minor surface rust on it now, but should i paint the inside of it? or not bother?
any info would be great.
Postby Dell'Orto » Sun Nov 23, 2008 8:49 pm
Wouldnt bother really, just wipe it with oil for the mean time.
Postby matt dunn » Sun Nov 23, 2008 8:58 pm
wouldn't put any paint on the inside, as where will it go if it flakes off?
Why did you get it hot tanked in the first place?
Normally you just clean and paint the outside and just clean the rest with petrol?
Postby thegreatestben » Sun Nov 23, 2008 9:22 pm
matt dunn wrote:wouldn't put any paint on the inside, as where will it go if it flakes off?
Normally you just clean and paint the inside and just clean the rest with petrol?
Lol, you mean the outside?
:P
thegreatestben
Postby matt dunn » Sun Nov 23, 2008 9:47 pm
thegreatestben wrote:Lol, you mean the outside?
:P
Um, yeah I did, lol.
Postby deaf_rattle » Sun Nov 23, 2008 9:49 pm
i got it hot tanked to get all the oil grime and rust off it.
might look at getting it pro coated or something maybe?
Postby Bazda » Mon Nov 24, 2008 3:23 pm
Just use some high temp engine paint.
As you prob want to get it baffled at some stage! so it would be a waste to pay for pro coating.
Postby IH8TEC » Mon Nov 24, 2008 3:27 pm
just baffle it now, i'm doing mine atm doesn't take too long
Postby deaf_rattle » Mon Nov 24, 2008 5:09 pm
IH8TEC wrote:just baffle it now, i'm doing mine atm doesn't take too long
want to do mine?
good thinking barry, will hold off pro coating for now.
Postby postfach » Mon Nov 24, 2008 5:18 pm
Hey Matt, if you want to baffle your sump let me know, I can help you out.
postfach
