help needed-megasquirt
Postby groupagt4 » Mon Nov 24, 2008 5:53 pm
ok i need help with my piece of crap megasquirt.
tuners tried to tune my car today(ae86 with silvertop turbo-t3.t4) they could tune it fine before boost but as soon as they tried to tune for boost the computer would not let them, they said it needed some other software. can any one please help me get this software. i looked everywhere cant find it, even the turbo software om megasquirts website doesnt work
groupagt4
Postby ChaosAD » Mon Nov 24, 2008 5:59 pm
Sounds weird that it wont let them tune for boost.
Are you running ms1 or ms2?
You can find the latest ms1/extra software herehttp://www.msextra.com/manuals/MS_Extra_Manual_Index.htm
ChaosAD
Postby groupagt4 » Mon Nov 24, 2008 6:32 pm
yea thats wat i thought. have no idea of it 1 or 2 is anyway to tell
groupagt4
Postby ChaosAD » Mon Nov 24, 2008 7:06 pm
Check in megatune. can go to msq info and check the version of the .msq you are using.
or using portchecker.exe
ChaosAD
Postby groupagt4 » Tue Nov 25, 2008 8:25 pm
ok went back to the tuner today with all the software i could find, still nothing. apparently its the board inside the ecu thats not right. CAN ANYONE please help me. is there a place i could send my ecu to that can put the right boards in for me. i really need this car going asap. or if no one knows is anyone selling a cheap link.
groupagt4
Postby ChaosAD » Tue Nov 25, 2008 9:23 pm
The standard map sensor on the v2.2 or v3 should take up to 21psi.
Did you build it? buy it prebuilt? or get it second hand?
The page I showed you was for the ms1 cpu. heres the one for the ms2.
http://www.msextra.com/ms2extra/index.html
Youll need to know which cpu you have.
If you pull the top cover off the ecu youll see a 40 pin socket which will either have a black chip (MS1) or a small board with a couple of chips and components on it (MS2) fitted to it.
The ms2 looks like this http://www.megamanual.com/ms2/
ChaosAD
Postby groupagt4 » Tue Nov 25, 2008 10:22 pm
ok pulled it apart. looks like the board has one long rectaNGULAR BLACK CHIP. the board says on it megasquirt v3 MB. and then theres another board that says msns_extra daughterboard v2. does this make any sense to you. oh and i bought the car with the megasquirt already in it. i looked on the tuning chart that the tuner brought up and it only goes to 100kpa,same with spark chart. does this mean i need a different kind of map sensor. this computer is confusing the shit outa me
groupagt4
Postby ChaosAD » Wed Nov 26, 2008 7:13 am
Ok so you will have the ms1 ecu. And it will be running ms1Extra software found at the first link I posted.
The msns-extra daughterboard is an extra board thats been fitted to give your ecu extra features such as boost control, launch control, VR input etc.
On the fuel and spark tables you can actually set the RPM and map values to whatever you want. 100kpa is zero boost, below that the manifold is under vacum, above 100kpa is boost. Make sure the numbers on the kpa scale go past 100kpa or you wont be able to tune for boost.
Eg http://www.msextra.com/manuals/MS_Extra_Tuning_Manual.htm#sparkmap
The other thing is that it may have been setup for Alpha-N (tps vs Rpm instead of map vs rpm).
This link from the manuals may help. http://www.msextra.com/manuals/MS_Extra_Tuning_Manual.htm#VESetts
Any chance you could post up the .msq?
ChaosAD
Postby groupagt4 » Wed Nov 26, 2008 6:28 pm
ok cool yea the tuner jus could not get it to go iver 100kpa is there a chance he just doesnt know what hes doing or could there be another reason. also wat is the .msq you want me to post up
groupagt4
Postby ChaosAD » Thu Nov 27, 2008 7:34 am
When you save a backup of your ecu tune to the laptop it saves it as a .msq file. It will contain all the settings, fuel/spark tables etc.
If you could get a recent .msq and post it up or email it to me I can have a quick look over it for you.
If you cant find where theyre saved just go into megatune with the ecu connected and go to 'save as' and save it to the desktop or something
ChaosAD
Postby groupagt4 » Thu Nov 27, 2008 6:25 pm
ok sweet ill email it to you, wats your email. i had a look on the tablr but it only comes up as a graph and i dont know how to get it so i can change the actual values. but ill send it to you anyway
groupagt4
Postby ChaosAD » Thu Nov 27, 2008 6:43 pm
Goto 'basic setup' > 'fuel VE table'
Will PM it to you.
ChaosAD
