firewall too hot
firewall too hot
Postby l1ttle_d3vil » Thu Dec 04, 2008 8:03 pm
I took the ke25 for a cane tonight, only for about 10 mins.
by the time I got back the firewall beside the dump pipe was too hot to touch, as in I now have a blistered finger :evil:
obviously this is a bit of a fire hazard with the carpet etc.
whats the best way I can reduce the heat? there isn't much room to re-route the dump pump, maybe 1" extra clearance max.
is there any sort of covering I can put between the floor and carpet or anything??
Postby xsspeed » Thu Dec 04, 2008 8:21 pm
Heat wrap the dump?
Postby l1ttle_d3vil » Thu Dec 04, 2008 8:46 pm
how well does that work?
and is it likely to crack?
Postby 85AW20v » Thu Dec 04, 2008 9:07 pm
The guys who do commercial refrigeration use some sort of heat shield blanket when they're brazing around fridge motors. See if you can track down some of that and attach it to the firewall. You can put a gastorch directly on to one side and not feel any heat on the other. Think it comes in 300mm squares and is silver both sides.
See ya
Simon
85 MR2 20v
85AW20v
Postby Trls250s » Thu Dec 04, 2008 9:21 pm
Make up some heat sheild out of stainless too and screw it in place.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby strx7 » Thu Dec 04, 2008 9:35 pm
Trls250s wrote:Make up some heat sheild out of stainless too and screw it in place.
Yip, hit the nail on the head, provided there is a bit of air space between the firewall and the heat sheild it'll be mint.
Postby IH8TEC » Thu Dec 04, 2008 9:52 pm
heatwrapping the dumppipe is not too bad and shouldn't cause it to crack, i think this would be your best bet if there is not much space, which sounds like the case if the firewall is getting that hot.
heatwrap on a manifold however will cause it to crack, happened to me, haven't used it on manifold since and it's been fine.
Postby d1 mule » Thu Dec 04, 2008 10:29 pm
pic 8 on crnkins carina auction has some sort of heat sheild stuff. pm him on GD im sure he would sort ya out
http://www.trademe.co.nz/Trade-Me-Motor ... 451511.htm
d1 mule
Postby xsspeed » Thu Dec 04, 2008 11:16 pm
IH8TEC wrote:heatwrapping the dumppipe is not too bad and shouldn't cause it to crack, i think this would be your best bet if there is not much space, which sounds like the case if the firewall is getting that hot.
Yeah I was assuming not much space between dump and firewall, if its getting hot and there is an air gap its cos of convection, so smaller gap = more heat transfer. If there is enough of an air gap go for the heat shield.
What is your dump pipe made from?
As for cracked manifold I was under the impression it depended what material it was made from as to whether you can get away with heat wrap? Can't specify more than that sorry, not sure which materials are affected but at a guess I would say you probably shouldn't be wrapping stainless steel, if thats what you have.
heat shielding
Postby ezy10s » Fri Dec 05, 2008 5:48 am
the heat shield used on crankins carina is available through repco- its awesome stuff- just cut it to the shape you want- drill a couple mounting holes and bolt it to whatever is available.
Member #244
ezy10s
Postby gepsk8 » Fri Dec 05, 2008 7:58 am
bit off subject but whats ur manifold weld with brendon?
cause my mates got si manifold, he was gona heat wrap but i might tell him no to if its gona crack.
O272754663
gepsk8
Postby NOLAW » Fri Dec 05, 2008 8:19 am
yeah i have a steam tube si manifold thats been heat wrapped, not gonna go un-doing it though, put so much time into wrapping it :lol:
NOLAW
Postby evil_si » Fri Dec 05, 2008 12:42 pm
im not a fan of heat wrapping,
i like stainless heat shields if room permits.
and insulating affected areas with heat resistant matting.
hpc do a ceramic coating that keeps heat in but the downside is it sucks your wallet dry,
evil_si
Postby tim_blair » Fri Dec 05, 2008 6:15 pm
ive made heat sheilding out of tinfoil and paper b4 works real well just roll out the tin foil put in a piece of paper fold the tinfoil over another piece of paper fold tin foil over another piece of paper, keep going to you hearts content
tim_blair
Postby IH8TEC » Fri Dec 05, 2008 9:12 pm
dunno what it's welded with, actiondan did it a few years ago, its a steamtube manifold though.
your other option is like suggested hpc, my mani and dp is procoated.
Postby levinguy » Fri Dec 05, 2008 10:53 pm
that stuff through repco, what is it called? and how much is it?
is it better then using stainless?
thanks!
levinguy
Postby Burning Angel » Sat Dec 06, 2008 7:29 am
its ACL heatshield material. i think the part # is HR140GTR
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby 1I1 » Sat Dec 06, 2008 10:39 am
Yeah its an ACL product. The stuff i got was 700x290. Its pretty good. Easy to use/piece of cake to bend etc. If you have the latest NZPC mag its the same stuff nick teeboon used in his AE86 around the strut tower and firewall
TRD Clicky >>Here
1I1
Re: firewall too hot
Postby allencr » Sat Dec 13, 2008 7:17 am
l1ttle_d3vil wrote: there isn't much room to re-route the dump pump, maybe 1" extra clearance max.
HOW much space between the exhaust and the firewall? I think it'd be better to contain it at its source then insulate inside. Metal plates work very well so Temporarily use a heat-shield or two, made out of anything available like a license plate or sheets of layered up of aluminum foil between the exhaust & firewall, with an air space in between. A piece of coat hanger can hold hold a prototype in place for a few hours of testing.
allencr
Postby fx gt » Sat Dec 13, 2008 1:19 pm
tim_blair wrote:ive made heat sheilding out of tinfoil and paper b4
:lol:
fx gt
