IH8TEC wrote:heatwrapping the dumppipe is not too bad and shouldn't cause it to crack, i think this would be your best bet if there is not much space, which sounds like the case if the firewall is getting that hot.
heatwrap on a manifold however will cause it to crack, happened to me, haven't used it on manifold since and it's been fine.
Yeah I was assuming not much space between dump and firewall, if its getting hot and there is an air gap its cos of convection, so smaller gap = more heat transfer. If there is enough of an air gap go for the heat shield.
What is your dump pipe made from?
As for cracked manifold I was under the impression it depended what material it was made from as to whether you can get away with heat wrap? Can't specify more than that sorry, not sure which materials are affected but at a guess I would say you probably shouldn't be wrapping stainless steel, if thats what you have.
