4age Valve Springs
4age Valve Springs
Postby shazeal » Fri Dec 05, 2008 11:56 am
Hiya,
I have been to every tool shop I can think of and had no luck finding a spring compressor that actually fits the 4age head. A helpful Repco employee told me the style of compressor I need is "out of fashion".
The closest thing Ive found is a Honda motorbike compressor but the top fitting was too big. Am I better just to rig something up to do this? I saw some threads mentioning using some tubes or something, but It didnt really make much sence to me as to how it all worked.
Or can someone tell me where I might be able to get the right tool? I have the springs off at the moment, socket + hammer did the job but I need to get it back together asap.
Thanks.
Current - 83 Levin AE85 Notch.
Ex - 89 Sprinter - Red Top, 88 Levin - 4agze.
shazeal
Postby Bazda » Fri Dec 05, 2008 1:09 pm
There is a tool which is hand held like a bicycle handle and has this little mechanisim inside.
You just dummy assemble the spring and retainer with the collets sitting in there, put something under the valve so it wont drop back down, and press this tool over the top of the retainer and collets which will be pressed into the valve stem. Then magic its all on.
Postby Burning Angel » Fri Dec 05, 2008 1:32 pm
like this thing
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby shazeal » Fri Dec 05, 2008 7:47 pm
That thing looks awsome, Im guessing theyre pretty steep price wise as Ive never seen one in any of the tool shops I frequent.
I found some really bad pitting in the valve seats after removing some scoring in the 2 cylinders that lost compression. Probably bits of the head gasket so Ill just get the engineering shop to re-assemble it all :/
Thanks for the replies though :)
shazeal
Postby matt dunn » Mon Dec 08, 2008 9:59 pm
Burning Angel wrote:
like this thing
Yeah but from where? I tried to get one of them thru my tool suppliers but had no luck.
I bought a double action valve spring compressor, and then had an end made for it which fits the small 20V heads.
Works a treat and I think all up owes me $125?
but since I have done about 5 heads now has paid for itself.
Postby 2LTR Rona » Mon Dec 08, 2008 10:11 pm
Matt - tried Sulco? they have a couple of items listed as "Valve Keeper Installer" although not the "hit" it style
Did find this on Amazon of all places
http://www.amazon.com/Magnetic-Valve-Ke ... B000K1NK8I
or from here http://www.sjdiscounttools.com/lis36200.html
2002 Altezza, 1974 KE25
2LTR Rona
