who's got a 3inch downpipe on their st205?
Postby rmf55 » Wed Dec 17, 2008 1:57 pm
just looking at the super cheap tard me ones but worried it won't fit that well. have heard horror stories about those cheap ones, cracking, too short, fouling on air con etc. can anyone allay my fears?
rmf55
Postby mr30%jr » Wed Dec 17, 2008 3:01 pm
yup they crack. pretty sure the XSPOWER ones crack but prob dependant on the way the exhaust is set up. if they are braced they prob survive.
not to sure about the aircon thing cause from what ive seen they have both been on sw20 style engines.
if you can id prob go with a steam pipe one off if there available.
mr30%jr
Postby RunningRich » Wed Dec 17, 2008 3:30 pm
I know someone who recently bought a trademe ST205 downpipe and the alignment was off.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby levinguy » Wed Dec 17, 2008 4:32 pm
i just took mine back in today after it had cracked on the weld, half way around the whole thing! the guys in the shop said they've sold heaps but this is the first one to come back, if i was to use another one again, i'd get a brace to bolt to the block and the bottom of the pipe, like the factory cat
levinguy
Postby rmf55 » Wed Dec 17, 2008 7:52 pm
hmmm thanks guys, thats definately enough issues to put me off.
rmf55
Postby Malcolm » Wed Dec 17, 2008 9:31 pm
I have an XS power DP on my mr2, I don't have aircon so can't comment on them hitting things but it all went on fine, and it hasn't cracked after over 20,000km of driving on an exhaust which doesn't even have a flex joint and only has 1 hanger. I was intending to improve the exhaust because I thought it would definitely cause the downpipe to crack, but I've been too lazy/busy to fix it, and it hasn't broken after lots of use.
Postby Malcolm » Wed Dec 17, 2008 9:32 pm
oh, the only problems I had were that the lower brace didn't really line up (only using 1 bolt to hold it on to the lower flange) and it came with bolts to replace the studs in the turbo but they were the wrong thread pitch
Postby Heylin » Thu Dec 18, 2008 1:02 pm
Ditto here, same setup and no problems with cracking on mine, welds are pretty meaty.
Only problem I had was having to add 30mm to the B pipe so it would meet the dump pipe. Incidently this involved replacing the whole length of B pipe at a cost of $200. I did have a full FGK exhaust system so this might explain why it was different to factory B pipe.
If youre concerned spend a bit more and get an Aussie 3" dump pipe.
Heylin
Heylin
Postby Al » Thu Dec 18, 2008 11:20 pm
Al
Postby Bazda » Fri Dec 19, 2008 2:39 pm
ANY stainless manifold, dump pipe needs to be braced, no matter who made it, without bracing over time it will crack.
When stainless gets red hot its very very flexible.
Postby rmf55 » Fri Dec 19, 2008 9:00 pm
the aussie is definately a quality item, but its also a big step up in price. like 3-4 times! I'm definately tempted by the ko racing item though: ceramic coated and 2.5" which i'd much prefer over 3". or an evil si custom one.
its just for the sake of $160 i'm tempted to try the xs power one. i think they're designed for an mr2 over an st205 so i'd anticipate more issues with me fitting it, in particualar i think it'll foul on my air con.
rmf55
Postby levinguy » Sat Dec 20, 2008 12:27 am
the $160 one's on trademe are not xs power ones, they are some generic brand for china, and do not come with any brace at all, only some bolts which are the wront size anwyay.
do not buy them unless you are going to brace the bottoms of them IMO
unless you want to learn the hard way like me
levinguy
Postby kim0663 » Tue Dec 23, 2008 11:07 am
i have one off tardme, the seller's name was Luxury Sports iirc
Driven around 10,000kms, no issues yet.
Fitment was good, all bolts were of correct pitch (which was a definate surprise) , waste gate didn't jam open either which the earlier XS ones seemed to do alot
AND it doesn't have any issues regarding a/c on a sw20. Factory cat pipe does not want to come out if you got a/c.... requires alot of love until it comes out and it's not something lightweight.
For $160, from my experience, i don't think you can go wrong lol
By the way, i don't have a support bracket. maybe i need one... hmm
Mr2 GT-S
330ci M
kim0663
Postby benj » Tue Dec 23, 2008 1:38 pm
I put a luxury sports one on my ST205, fitment was reasonable, bolts fitted fine, 2500km so far and no problems.
1997 JDM ST205 - Busted!
2009 Ford Mondeo Diesel
2000 Audi A4 Quattro 2.4
1981 Landrover Series III Diesel
benj
Postby Prymal » Tue Dec 23, 2008 8:55 pm
i have a genuine aussie exhausts one ..
had one on my previous 185 group A as well ..
5 + years of abuse , both still look like new and have no cracks
you pay 4 times more because of QUALITY AND FITMENT..
its like buying cheap shitty chinese rubber and expecting them to handle like proper michelen pilots when rallying .. Its not gunna happen ..
Save - buy the genuine item , never look back ..
Prymal
Postby st205 gt4 » Sat Jan 24, 2009 5:19 am
well i have the xs power down pipe not braced nothing to brace it to an yeah alignment was off bit it doesnt leak an i have removed the aircon as well goes great on my st205 :)
st205 gt4
