4K engine into starlet
Postby Nezza » Thu Dec 18, 2008 9:47 am
Will 4k eninge and 5 speed gearbox from a ke70 corolla fit into kp60 1981 starlet? I think the engine bolts straight in, not sure bout gearbox. Will i have to cut a hole for shifter?
Nezza
Postby GTTpower » Thu Dec 18, 2008 9:59 am
Yes you will need to cut the tunnel to make the gbox fit. Engine bolts straight in
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Postby rwd_mayhem » Thu Dec 18, 2008 1:56 pm
you will have to cut a hole for the shifter to come through as the ke70 gboxs are a bit longer.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby Dell'Orto » Thu Dec 18, 2008 5:31 pm
Gearbox is the same length, shifter position is different
Postby Nezza » Fri Dec 19, 2008 7:39 am
Im having trouble finding a K50 gearbox to fit into the starlet. All i can find is one from a ke70 corolla, if its going to fit with out to much trouble i may aswell buy it
Nezza
Postby Dell'Orto » Fri Dec 19, 2008 7:40 am
Yeah the Starlet ones are much harder to come by. Its not hard to trim the gearshifter hole to suit a KE70, though the centre console might foul slightly.
Postby Nezza » Fri Dec 19, 2008 12:00 pm
[/quote]though the centre console might foul slightly
WHat you mean
Nezza
Postby Dell'Orto » Fri Dec 19, 2008 12:58 pm
The plastic bit that the gearlever comes up through, with the lever being about 50mm further back it can hit the surround when you pick 2nd and 4th. Just trim it to suit, or remove it.
