Corona st170 3SGTE wagon - Misfire!
Postby CelicaGT8 » Sat Jan 03, 2009 12:41 am
I have built a hybrid 3sgte - 165 block with 185 head - forged pistons, external and all the usual bs... and put it into a 170 corona wagon.
It runs great untill it gets to about 0psi on the boost gauge, then it sort of holds back, then sends the car flying forwards untill it reaches around 10 - 14psi, then it just back fires and farts around.
Iv had a simular problem with a 3s engine before, but cant rember what i did to solve it...
Any help would be AUSM!
:lol:
How do you insert a pic? lol
CelicaGT8
Postby mr30%jr » Sat Jan 03, 2009 10:55 am
its really dependant on what ECU you are running
st165? aftermarket? st185? sounds like my st165 but 10X worse. (the afm was bouncing so bad it cuts the fuel pump)
upload the pic to someone like
www.imageshack.us
copy and paste the forum image link here in a post.
mr30%jr
Postby Akane » Sat Jan 03, 2009 12:37 pm
It happened to me once that I'd full throttle and the car will go nowhere, nowhere as in 1300rpm and struggle to take off and will just sit there all day. Turns out my cam timing was way off, making the dizzy's firing way off. I rangi fixed it by full advance on the dizzy, then later proper fixed it with putting the cam forward 1 tooth on the cambelt (back to original position)
Postby CelicaGT8 » Sat Jan 03, 2009 2:46 pm
I made a custom loom, but running all the 185 sensors for the computer and running a 185 computer.
It came up with a knock sensor code - u think that could be the prob?
Um - does anyone have one?? im using a levin one 20v
CelicaGT8
Postby CelicaGT8 » Sat Jan 03, 2009 5:29 pm
Just a small sample... still needs work...
CelicaGT8
Postby Akane » Sat Jan 03, 2009 8:31 pm
I do have a 3S-GTE knock sensor, PM me if you do want it.
Postby Twolitre » Sat Jan 03, 2009 9:15 pm
A knock sensor fault will cause it to run like shit but when you said it flies forward after hesitating do you mean accelerate quickly? Becuase that would be unlikely with a knock sensor fault.
Worn dissy cap, rotor & leads would cause major hesitation and misfiring.
Don't forget that pre & post facelift ST185/SW20's have a different plug on the knock sensor and did you run shielded cable to the knock sensor?
Twolitre
Re: Corona st170 3SGTE wagon - Misfire!
Postby FXGTV » Sat Jan 03, 2009 10:17 pm
CelicaGT8 wrote:I have built a hybrid 3sgte - 165 block with 185 head - forged pistons, external and all the usual bs... and put it into a 170 corona wagon.
:lol:
Sounds exactly like what happened to my 3sgte. My afm was shot so I got one off a 3ltr v6 windom and it fitted perfectly. The only thing was it was a lot larger than the original one. It made it run how you're describing, cough and splutter, then a big surge of boost. I know you havn't got a v6 windom afm , but maybe your afm is rooted. :P
1988 r31 TI Skyline.
FXGTV
Postby CelicaGT8 » Sun Jan 04, 2009 12:13 am
The wire to the knock sensor has a earth shield around it.
The dissy cap is mint, and has new leads.
Yea once it hesitates around 0psi it accelerates like it should untill it gets higher boost. then it back fires and runs like total crapp!
Ill get that dam knock sensor fixed then get back to you all.
Thanks for your help so far.
But does anyone know where/ how i can flair my intercooler piping.
it popping off is sooo gay.
CelicaGT8
Postby mr30%jr » Sun Jan 04, 2009 11:47 pm
nice liking your gen1 3SGE side intake thinking of doing the same...
i would be around the AFM area...
are you using st165 afm? they are different through the series.
mr30%jr
Postby CelicaGT8 » Sun Jan 04, 2009 11:52 pm
Yea iv done afew with the na intakes - work well, and get rid of that dam tvis lol, i hate it.
Im not tooo sure to be honest.... it could be a 165 one..... ill try changin it.... but i think thats my only turbo one these days... could try an NA one i gess.
CelicaGT8
Postby ee904age » Mon Jan 05, 2009 8:31 pm
CelicaGT8 wrote:But does anyone know where/ how i can flair my intercooler piping.
it popping off is sooo [person of homosexual orientation].
Get somebody to run a weld around it?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby CelicaGT8 » Mon Jan 05, 2009 11:45 pm
I thaught about tigging around it, but i didnt think that was going to look quite as good - not like anyone will see it tho.
But if it was easy to do then id like to have it done right.
although i still have to get some welding done to get rid of the joiners...
CelicaGT8
Postby Malcolm » Mon Jan 05, 2009 11:53 pm
if the piping is aluminium then you can easily roll a bead on it with a swaging tool, Alert Engineering have one that'll do it easy
Postby CelicaGT8 » Tue Jan 06, 2009 3:40 pm
OW yea... where are they?
Does anyone know if a 4age 20v knock sensor will work on a 3sgte?
CelicaGT8
Postby Malcolm » Tue Jan 06, 2009 8:07 pm
they're in the phone book. :P
but because I have a business card here, I'll tell you. Unit 5, 4 Clemow Drive, Mt Welly.
A 4agze sensor may share the plug & thread, but knock sensors are tuned to resonate at the frequency at which the engine knocks (which i believe has something to do with cylinder bore, but TBH I don't really know). You're much better off getting one from a 3s (I imagine that fe/ge/gte should all be the same, but i could be wrong)
Postby levinguy » Tue Jan 06, 2009 10:55 pm
for reference, st182 3sges have the same knock sensor, the 20 valve one bolts in, but has a different plug
levinguy
