Just the battery?
Just the battery?
Postby AE86less » Tue Jan 13, 2009 12:21 pm
I'm pretty sure I've got this one figured out, but wanted to double check as I don't want to be selling the Levin (BT 4age) as a lemon.
The story goes that I went away for a while and when I came back and went to go for a drive the curn turned over a few times and then started clicking like it had a flat battery. Jump started it, drove around for 15 mintues then came back and tried to start it, turns over then clicks. Damn.
At that stage I took the battery to put in the KE70 (standard 4k) I just bought, put it in, jumpstarted and drove as per normal for several weeks. Then a couple of days ago I went to put the battery back in the Levin: turn, turn, click. WTF, that battery has been turning over the KE70 for a good 30 seconds before it starts everytime, it should be mint. Put the battery back in the KE70 and start it up fine with no jumpstart.
To me it sounds like the battery no longer has the grunt to turn over a high comp engine? (fingers crossed)
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby xsspeed » Tue Jan 13, 2009 12:45 pm
If it can handle the mighty 4k it should turn over a truck motor lol
Sounds like it is battery to me. Had the same thing with our caldina. Would struggle on that, but fine on a 2e corolla
Postby AE86less » Tue Jan 13, 2009 12:59 pm
Sweet as. I was pretty sure, but then started stressing that it might not be :lol: :oops:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby xsspeed » Tue Jan 13, 2009 1:01 pm
Try the one outta that caldina you rolled up to mine in
Postby Bradles » Tue Jan 13, 2009 1:24 pm
generally speaking, the clicking indicates bad contact and/or flat battery, usually both.
Last tiem that happened to me i just went down to repco, grabbed some new battery lead clamp thingys, put them on, and it was fine again.
Bradles
Postby Bling » Tue Jan 13, 2009 1:49 pm
95% just battery. I wouldn't expect bad contacts on a newer car.
4k will not match the high compression of the BT. Which will make a difference as to how much juice a car needs to turn over. (I think)
Postby Bradles » Tue Jan 13, 2009 1:52 pm
BZG|Bling wrote:95% just battery. I wouldn't expect bad contacts on a newer car.
mine was a '97 with a blacktop :S
Bradles
Postby AE86less » Tue Jan 13, 2009 2:42 pm
Sweet. I'll point that out as well as the battery to the guy whos coming this arvo. Unless he sees it here first :P
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby pc » Tue Jan 13, 2009 6:51 pm
I had this just recently... turned out that my battery was dying, but I put other batteries in and got the clicking also.
The brushes on the starter motor needed replacing.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby johndoe1025 » Tue Jan 13, 2009 9:13 pm
if you reaaly wana make sure, run a jumperlead, one end connected tot he positive on your batt, the other to the positive stud on your starter, then crank, thatl tell you if you got massive voltage drop down the wire
EP82 GT-went mega hard for completely stock, 15.09 quarter, gone now :(
AE111 Levin BZG current! 4AGTE next? you never know....
johndoe1025
Postby B1NZ » Tue Jan 13, 2009 10:19 pm
may sound like a silly question but are the battery terminals tight? Seen it lots of times before :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
