I'm doing the cambelt on the 4E-FE, and kinda baffled by the simple tensioners they have, I have not come across anything like this.
Usually on the MR2, the tensioner has a retracting / extending rod that pushes a roller on a pivot, to reuse you simply slowly clamp it on a vice and put the pin back in.
But the 4E-FE one I see here (I havn't taken it off yet in fear of doing something wrong), is a roller on a pivot point that's PULLED with a visible pull spring, WTF? How do I reuse one of these? How do they work because I took the spring off but the roller won't shift at all (duh). I tried google but no help.
