cambelt tensioner
cambelt tensioner
Postby Akane » Wed Jan 14, 2009 6:36 pm
I'm doing the cambelt on the 4E-FE, and kinda baffled by the simple tensioners they have, I have not come across anything like this.
Usually on the MR2, the tensioner has a retracting / extending rod that pushes a roller on a pivot, to reuse you simply slowly clamp it on a vice and put the pin back in.
But the 4E-FE one I see here (I havn't taken it off yet in fear of doing something wrong), is a roller on a pivot point that's PULLED with a visible pull spring, WTF? How do I reuse one of these? How do they work because I took the spring off but the roller won't shift at all (duh). I tried google but no help.
Re: cambelt tensioner
Postby Jason T » Wed Jan 14, 2009 6:49 pm
Akane wrote:I'm doing the cambelt on the 4E-FE, and kinda baffled by the simple tensioners they have, I have not come across anything like this.
Early style the spring sets tension
Here is a basic how to with tourqe settings you can use
Fixing Toyota's since '87
Jason T
Postby matt dunn » Wed Jan 14, 2009 7:22 pm
sounds the be the same as a normal 4age tensioner.
Undo the bolt in the centre of the tensioner wheel,
the wheel wil move freely back and forth,
and the spring hold tension on the belt.
Postby Akane » Wed Jan 14, 2009 7:28 pm
Oh my god i undone the spring for nothing then.
so the way this tensioner works is that you set the static tension yourself and have the keeper spring there to hold it in place and hope the tension stays?
Cheers guys for the help, doing cambelt on this thing ain't as hard as I thought.
Postby Lloyd » Wed Jan 14, 2009 7:35 pm
No.
You have the covers off so the belt is all sitting there. The tensioner is locked in place by the bolt.
Crack the bolt slightyl loose and the tensioner will pivot, the spring simply holds it against the belt at a set tension.
Pull one side of the belt and the tensioner moves back, tighten the bolt and it will stay there.
Take the old belt off and fit the new one.
Crack the bolt loose and it will tension the belt (well, you'll have to give the cams a wiggle to settle the belt in but you know...)
Tighten the bolt
Tun the engine over a couple of turns and check the belt tension.
Postby matt dunn » Wed Jan 14, 2009 7:37 pm
Akane wrote:Oh my god i undone the spring for nothing then.
Not really,
if you have the spring off the tensioner will flop backwards and forwards with no belt, pivoting on a small pivot out to the side.
Put the spring on,
push the tensioner back full travel to stretch the spring,
lock the cenre bolt to hold it there,
put the belt on,
loosen the centre bolt and the spring will pull the tensioer against the belt to the correct tension,
tighten the centre bolt again.
