LSD Noises
LSD Noises
Postby Adoom » Fri Jan 16, 2009 4:26 pm
I have a TRD 2way LSD in a T-Series diff. I am running Castrol LSX 140. I used to run Redline(I forget the number).
Sometimes when turning in small circles at low speed I get a bang from the rear end. I used to think it was the rodends from the 5Link but now I have changed it to urethane bushes(there is nothing to bang).
Is it just the LSD? Is it normal? Can I stop flinching when it happens?
Adoom
Postby rollaholic » Fri Jan 16, 2009 4:35 pm
i get a few shudders and such from the same setup in my car. apparently you can get a slip additive from toyota (and probably elsewhere) that gets rid of it. i believe its caused by the clutch packs being right on the edge of engagement, so they engage, then disengage, and so on. give it a bit more power and it goes away as they lock up properly :D
Postby FLAWLES » Fri Jan 16, 2009 4:55 pm
lsd's hate low speed turning :wink: honestly they do
so best you speed your turning up a notch or two :wink:
may not be diff tho
check control arms and what not,
FLAWLES
Postby AceSniper » Fri Jan 16, 2009 5:12 pm
AceSniper
Postby Akane » Fri Jan 16, 2009 6:31 pm
Nismo GT Pro LSD does it, clonks at low speed tight turnings (u turns etc). It's a sign that you're hardcore.
Postby Adoom » Fri Jan 16, 2009 11:00 pm
Akane wrote:Nismo GT Pro LSD does it, clonks at low speed tight turnings (u turns etc). It's a sign that you're hardcore.
But the majority of the human sheep don't know clunking is hardcore rather than broken.
Adoom
Postby 79rolla » Fri Jan 16, 2009 11:33 pm
tthen make a sticker sayin "if it clonks its hardcore" or sumthin to that affect... then give heaps ov them out and you will be hardcore!!
past: AE82 FXGT
79rolla
