Crank pulley removal 20v
Postby gleem » Sat Jan 17, 2009 4:22 pm
Im having trouble removing the crank pulley on my blacktop 20v. after 2hrs i managed to get the bold of. But now i cant get the pulley of and i cant see anythinh holding it on. Ive put jimmy bars unfer and bit it with a mallet but it wont budge. Am i missing something
gleem
Postby Stott69 » Sat Jan 17, 2009 5:09 pm
just removed mine, had to use a pulley puller, can get them from repco and supercheap i think.
Image jzs147 Aristo money pit
Stott69
Postby 20v_rollaboy » Sat Jan 17, 2009 5:37 pm
Have one you can borrow if you like.
Oh, I dont need that engine anymore :lol:
20v_rollaboy
Postby Akane » Sat Jan 17, 2009 7:46 pm
damn only if I had a crank pulley puller
I did mine by tapping the edge and rotate, tap the edge etc with a hammer, took a while but finally got it off.
Postby Voyeur » Sat Jan 17, 2009 9:32 pm
I made a tool for mine. Bit of box steel long enough to sit on the face of the pulley, with a 10mm hole in the middle, and 2 6mm holes at the same spacing as the threads on the pulley. bolt the box to the pulley, with they pulley bolt in the crank but loosen 2 turns, insert 10mm bolt in centre hole with a standard nut on the pulley side, tighten till it stops, then loosen off, undo crank bolt a bit more and repeat. easy as.
2005 vz ss commodore
Voyeur
Postby frost » Sun Jan 18, 2009 2:41 am
^^^ did the same thing works a treat and CHEAP :D
