tsoob wrote:my understanding was the normal procedure is to change the crank pulley to give more boost from these chargers?
~SlideWays~ wrote:tsoob wrote:my understanding was the normal procedure is to change the crank pulley to give more boost from these chargers?
Yep thats the normal way but on the SC14 conversion onto other motors its easier to fit a smaller pulley to the supercharger which effectively does the same thing. But all the smaller pulleys I've seen have just been a normal pulley ie no clutch, so its on all the time.
Infact Im pretty sure there are 2 different diameter supercharger clutch pulley's, the later ones being smaller.
gleem wrote:ok ill just remove the whole supercharger itself. Has anybody done the blocking of the air bypass vlave and is it nessesary?
