blocking off aircon plumming
Postby gleem » Mon Jan 19, 2009 9:37 am
ive recently removed all the interior aircon and associated pipes. now there is 2 lines removed theat carry coolant in side the car. ive removed these and now theres 2 holse in the themostat housing etc goin now were. Whats the best thing to block them with.
gleem
Postby jakesae101 » Mon Jan 19, 2009 11:01 am
those are heater hoses for the heater matrix id sugest getting the holes welded up in the housing or have seen short bits of hose with a big bolt in one end and hose clamp used dont know how well it worked
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby 79rolla » Mon Jan 19, 2009 12:21 pm
yeah hose with a bolt hoseclamped off works, aslong as the bolt doesint have a huge thread on it..
also if both hoses come from the same side of the thermistat you can just use a small loop of heater hose, doesint matter if it gets folded/crimped off with a tight bend to use least hose posibail...
http://s102.photobucket.com/albums/m109 ... G_1979.jpg look above geairbox at thermistat housing (hose sticking up)
past: AE82 FXGT
79rolla
Postby stalker » Wed Mar 11, 2009 12:08 am
Sorry to bring up an old thread......just wanting to double check before its too late
So it is ok to just weld up the holes (highlighted in green) if the whole heater unit has been removed??
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby gleem » Wed Mar 11, 2009 8:33 am
i didnt end up welding has i have no gear so i just used i bit of pipe and put one end over both
gleem
Postby stalker » Wed Mar 11, 2009 10:05 am
Ahh true.
Yea, I have that at the moment, but am hopeing that im correct in thinking that no water will flow throu it as I have totally removed all the heater unit, as im wanting to turn the T-stat around to face 180 the other way as its a RWD set up, and cant have any pipes there otherwise I cant turn the t-stat around (if that makes any sence) lol
stalker
Postby gleem » Wed Mar 11, 2009 10:24 am
weld it up if you have the grear or fet a bit of pipe and put a big tight bolt in it and then put claps around that
gleem
Postby stalker » Wed Mar 11, 2009 10:30 am
Awesome! Thought I had better double check before I did anything
Cheers.
stalker
Postby Bazda » Wed Mar 11, 2009 12:06 pm
Dont you need a heater for WOF purposes?
ie window dimister.
Postby NZ_AE86 » Wed Mar 11, 2009 12:16 pm
Bazda wrote:Dont you need a heater for WOF purposes?
ie window dimister.
Not for WOF, only for motorsport - seems crazy I know!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby stalker » Wed Mar 11, 2009 3:59 pm
ie window dimister.
Hope they never change that law too!!
Cause when I brought the car it had no heater unit due to the cut in the firewall to allow the silvertop lol
stalker
