turboing on sandard ecu?
Postby 79rolla » Thu Jan 22, 2009 3:00 pm
just folowing up from my other topic, can i run my standard ecu (18rgeu) with boost (about 6psi) and bigger injectors (440cc rb20det) ?
will it need to be tuned? can you tune these ecu's? if so who can do it in the waikato? or will i need an aftermarket one? (i cant relly afford it at the moment)
in case you didn't realize i don't know allot about tuning turbo motors.
cheres for any help
past: AE82 FXGT
79rolla
Postby thegreatestben » Thu Jan 22, 2009 3:06 pm
thegreatestben
Postby 79rolla » Thu Jan 22, 2009 10:42 pm
everything on there is about running high boost levils so they need aftermarket ecu's understandably. but is it still necessary for low boost?? when i get more money and if i decide i want more boost ill invest in boost controller and ecu ect.. but its not relly an option atm unless it is truly needed
past: AE82 FXGT
79rolla
Postby bluemaumau » Thu Jan 22, 2009 11:04 pm
dont think rb20s are 440cc man, more close to 270-300 id say
Postby RomanV » Thu Jan 22, 2009 11:32 pm
You cant really change the injector size without changing the ECU.
Unless you can bodge it all with a piggy back, or a different AFM or MAP sensor or something.
But it's not a 'plug em in and go' type deal.
Postby Mr.Phreak » Fri Jan 23, 2009 12:20 am
If you can't afford an ECU, then how will you be able to afford to rebuild an engine :wink:
Mr.Phreak
Postby cat007 » Fri Jan 23, 2009 8:42 am
bluemaumau wrote:dont think rb20s are 440cc man, more close to 270-300 id say
Yeah - they're actually smaller than 1G-GTE injectors (which are 320-330cc).
I think RB20's are about 290cc?
Postby 79rolla » Fri Jan 23, 2009 9:08 am
ok, so im gonna $&#$% it ven on low boost unless i get a piggyback or something? damm, is there anything decent i can get for like $200 or something??
the reason i dnt have the funds is i only just decyeded to turbo it so i had never budgeted for it... ant at the moment i dont have an income... :(
past: AE82 FXGT
79rolla
Postby iOnic » Fri Jan 23, 2009 9:17 am
if you can't afford to do it properly don't do it at all. it'll be an even more expensive fix when it blows up because of cutting corners.
Re: turboing on sandard ecu?
Postby bbq1988 » Fri Jan 23, 2009 9:54 am
79rolla wrote:just folowing up from my other topic, can i run my standard ecu (18rgeu) with boost (about 6psi) and bigger injectors (440cc rb20det) ?
cheres for any help
Theyr out of a SR20DET (GTIR) Bro, 440cc
bbq1988
Postby bbq1988 » Fri Jan 23, 2009 9:55 am
get a 3tgt ecu?
bbq1988
Postby 79rolla » Fri Jan 23, 2009 11:40 am
oh shit.. typo.. ment to type sr lolz :oops:
would a 3t ecu run alright with thoes injectors? or wuld i need to get 3tgte injectors aswell??
past: AE82 FXGT
79rolla
Postby JustinSpiderholden » Fri Jan 23, 2009 11:46 am
79rolla wrote:oh sh*t.. typo.. ment to type sr lolz :oops:
Don't even bother trying to rewire with 3t ecu, way to much work
Your better off to wait a while long and try and find a cheap older link on trade me, there have been a few on there for around the $600 mark
You are better off to do it once do it right
JustinSpiderholden
Postby 79rolla » Fri Jan 23, 2009 3:59 pm
so would something like this do?
http://www.trademe.co.nz/Trade-Me-Motor ... 601452.htm
or should i just get
http://www.trademe.co.nz/Trade-Me-Motor ... 816125.htm
or something similer?
past: AE82 FXGT
79rolla
Postby JustinSpiderholden » Fri Jan 23, 2009 4:07 pm
79rolla wrote:so would something like this do?
Neither of those options will work, the map2 ecu won't interface with the older toyota ecus as they are such old technolgy
The second ecu is a link plug in jobby for a honda so it won't work either
http://www.trademe.co.nz/Browse/Listing ... =193594148 or GD Link http://www.garagedori.com/forum/viewtop ... f=4&t=5625
something like that would be perfect
JustinSpiderholden
