2jz q
2jz q
Postby evil_si » Thu Jan 22, 2009 9:38 pm
does any one know if 2jzge and 2jzgte cranks the same??
evil_si
Postby strx7 » Thu Jan 22, 2009 10:05 pm
yip they sure are.
Postby evil_si » Fri Jan 23, 2009 7:06 am
sweet cheers for that, now anyone have a 2jz crank they want to sell me??
evil_si
Postby strx7 » Fri Jan 23, 2009 12:19 pm
not all that easier thing to find, cause they are such a hard engine to kill
Postby evil_si » Fri Jan 23, 2009 6:28 pm
hmm this one wasnt so hard to kill :lol:
evil_si
Postby levinguy » Fri Jan 23, 2009 11:06 pm
evil_si wrote:hmm this one wasnt so hard to kill :lol:
those turbos might have something to do with it.... :P
levinguy
Postby strx7 » Sat Jan 24, 2009 8:17 am
what did you do to it?
Postby evil_si » Sat Jan 24, 2009 8:53 am
290 wkw on 9psi, modified the manifolds and got it running 18psi
havent pulled it apart yet as cant get the sump off in place,
but the oil sample results are bad,
very high silica, or dirt apparently the guys that tuned it did an oil change, the lab doesnt believe me that it was around 1500km ago, they say the oil is very old!
engine started making a nasty knocking noise under boost,
this is a screen, partical count of the oil sampled. bear in mind this is under a microscope,
evil_si
Postby YeMs » Mon Jan 26, 2009 11:45 am
shit that doesnt look good. what oil is it? i run shaeffers (spelling?) in my 2jz, absolutely awesome oil. nearly no pressure drop at all.
Your local Hybrid Elite tech
YeMs
Postby evil_si » Mon Jan 26, 2009 12:38 pm
no idea of the oil brand, the car tune company did the oil change when it was tuned,
have the engine out and stripped now, #3 big end has spun, crank doesnt look to bad, i guess the machinists will soon tell me if its usable or not,
rest of the engine is badly contaminated main bearings and cam journals have had a beating, fine metallic paste through everything,
evil_si
Postby Py7h0n » Mon Jan 26, 2009 2:54 pm
should be fixable - Very hard to kill a 2JZ.
Just get it all ground to .20 thou and get everything properly cleaned!
Do the rings while you are in there - If you can't find 2JZ rings then use 3S-FE ones (same part, just 4 not 6 :P)
Py7h0n
Postby mjrstar » Mon Jan 26, 2009 4:43 pm
copper and iron results are pretty low for an engine that has spun a bearing you must have caught it reasonably early we normally expect to see 75 plus. the one that is confusing me is the Lead! it seems very high. maybe the sample wasn't taken with the oil at it's hottest. makes interesting reading anyway
good luck withy the rebuild.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby evil_si » Mon Jan 26, 2009 5:16 pm
i think we were very lucky with when we caught it,
having access to decent oil sampling definatly helps
ill be taking the block and head to work tomorrow and run them thru the acid tank.
going to send the crank and cams to machinists,
may as well get cams ground while its apart dont think adam will shell out for new race cams
evil_si
