Hunting Idle in an AW11- From What?
Postby no_8wire » Wed Feb 04, 2009 6:40 pm
Previously the car had been running beautiful - better than a stock idle smooth as and at about 900rpm
My car stopped running right, so I repaired what I thought was the problem and sent it to the tuner to retune it. After getting it to start he informed me that the cambelt was loose - (ie was what had gone wrong)
After I redid the cam timing, I have tried playing with the dizzy timing to see if I can get a steady idle but it seems to hunt up or down by about 500rpm.
The engine is a 7agte, and I have blocked off or removed all the cold idle up that was stock on the AW11.
Here is a clip of the idle (ignore the 1st 15sec, thats me giving it a rev)
http://www.youtube.com/watch?v=gVvFqeTC71o
Is it more likely to be a tune issue, air leak, or something else?
- this car is starting to piss me off so any helpful advice would be appreciated.
no_8wire
