Max Oil pressure
Max Oil pressure
Postby gtpornstar » Sat Feb 07, 2009 12:14 am
What oil pressure is too high ? I did the shim trick and wondering is 6bar too high and whats the worst that can happen ?
Toyota Glanza 1.5L motor.
Toyota Starlet GT 90
Toyota Glanza V 96
Toyota Supra N/A 94
gtpornstar
Postby Lloyd » Sat Feb 07, 2009 12:23 am
Hot/cold revs/idle? Thats getting pretty high
Why were you needing higher pressure anyway?
Postby Adydas » Sat Feb 07, 2009 12:55 am
i run approx 4 bar at max.. Possible 4.2 if i looked accuratly..
If that helps..
Adydas
Postby gtpornstar » Sat Feb 07, 2009 1:41 am
HRT wrote:Hot/cold revs/idle? Thats getting pretty high
Hiya
This is Max so any given rpm this is the max, this is at cold.
Warm it gets up to 5bar.
Why did I do it ? safety i suppose, especially when on the track.
Seems to take longer for any pressure to build up now though :(
Toyota Glanza V 96
Toyota Supra N/A 94
gtpornstar
Postby strx7 » Sat Feb 07, 2009 7:24 am
the 2jz in my ex surf ran 90-95psi cold. the 5sgte in my corolla does the same. once upto temp they drop back (obviously) the surf ran around 60-65psi at 2500rpm. the 5sgte is similar and up the rev range the pin the gauge onto the 100psi stopper
Postby Burning Angel » Sat Feb 07, 2009 7:29 am
having higher pressure isn't going to give you any benefits really, if you go fast round a corner and the oil runs away from the pickup your still going to lose pressure.
although 4-5bar when up to temp is still a good pressure at max revs
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Bazda » Sat Feb 07, 2009 8:32 am
I would try keep it around 70-80psi at max revs when hot.
If the pressure is too high, this is not good for the bearings as the oil will pass by too fast.
Postby fivebob » Sat Feb 07, 2009 9:07 am
Bazda wrote:IIf the pressure is too high, this is not good for the bearings as the oil will pass by too fast.
Eh, where did that idea come from?
It's certainly not the case with plain bearing engines. Needle rollers & ball bearings are a slightly different story though.
Postby Bazda » Sat Feb 07, 2009 9:26 am
high oil pressure can cause the oil not to lubricate the bearings properly.
This is what I have heard, how high im unsure. And the theory behind it I am unsure but what i've heard from engine builders for years now.
Postby Celica RA45 » Sat Feb 07, 2009 10:11 am
the 3sge altezza motor when cold is 800 kpa and when hot is 650 kpa in old scale about 120 and 90 and this is std on all altezza 3sge for the vvti
this is using a mechanical guage
i rev this to 8800 rpm and have no oil problems with a wet sump around race tracks
Celica RA45
Postby RedMist » Sat Feb 07, 2009 10:34 am
You're more in danger of blowing an oil seal, popping the oil filter or possibly damaging the pump.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby gtpornstar » Sat Feb 07, 2009 12:11 pm
thanks guys so i am probably at the limit then.
RedMist - Which oil seal is under pressure besides he oil pump seal? Or can it vary from engine to engine.
Toyota Glanza V 96
Toyota Supra N/A 94
gtpornstar
Postby allencr » Mon Feb 09, 2009 9:25 pm
Oil filter has the only seal under pressure in any I know of
Breaking the pump or bursting the filter are a good possibility.
Oil too fast. :roll:
allencr
Postby strx7 » Mon Feb 09, 2009 10:12 pm
in a rotary high oil pressure will ensure everything keeps spinning freely. I have witnessed a 12A PP race motor which at idle when hot had around 115psi, and 150ish at full noise. A engine builder in the states had a drag strip 13B PP running at 190psi at full revs. His engines never die from lack of oil......
Postby Lloyd » Mon Feb 09, 2009 10:22 pm
