Tacho Sender Wire ????
Postby Gt_189 » Mon Feb 09, 2009 5:36 pm
Does any one know where the sender wire for the tacho is on a 1993 ep82 gt starlet?? i think it may be the green wire coming off the coil but want to make sure before cuting wire
Thanks
Cars: 1990 Holden Commodore Race Car
1993 Toyota Starlet Gt
Gt_189
Postby MrOizo » Mon Feb 09, 2009 6:05 pm
Is this for aftermarket gauge?
MrOizo
Toyspeed Legend
Postby Gt_189 » Mon Feb 09, 2009 6:48 pm
Yes it is.
Gt_189
Postby matt dunn » Mon Feb 09, 2009 6:57 pm
is there ig- in the diagnostic box?
Postby Gt_189 » Mon Feb 09, 2009 9:58 pm
um nt sure, but all good found the wire its a black and white wire coming off the coil.
Gt_189
Postby kim0663 » Mon Feb 09, 2009 10:21 pm
splice it into the gauge cluster loom?
Mr2 GT-S
330ci M
kim0663
Postby Mr.Phreak » Tue Feb 10, 2009 12:50 am
kim0663 wrote:splice it into the gauge cluster loom?
C'mon, if there was a factory tacho, he wouldn't need to add one :wink:
Mr.Phreak
Postby kim0663 » Tue Feb 10, 2009 12:53 am
but he does have one! :lol: i had a starlet before too and er...
i think i had two tachos in that thing :oops:
Mr2 GT-S
330ci M
kim0663
Re: Tacho Sender Wire ????
Postby Bradles » Tue Feb 10, 2009 9:36 am
Gt_189 wrote:Does any one know where the sender wire for the tacho is on a 1993 ep82 gt starlet?? i think it may be the green wire coming off the coil but want to make sure before cuting wire
Thanks
it should be the negative side of the coil, on any vehicle, for a tacho, no?
Bradles
Postby Gt_189 » Tue Feb 10, 2009 6:20 pm
um yea it negative side of the coil, a black a and white wire coming off the plug that plugs into the coil
yea and it is on any vehicle but wasnt too sure with this because of the coil.
Gt_189
Postby matt dunn » Tue Feb 10, 2009 6:43 pm
Bradles wrote:[
Nope, most toyota's since mid 80's have feed the tacho via a signal from the igniter.
