Does any one know where the sender wire for the tacho is on a 1993 ep82 gt starlet?? i think it may be the green wire coming off the coil but want to make sure before cuting wire
Thanks
Gt_189 wrote:Does any one know where the sender wire for the tacho is on a 1993 ep82 gt starlet?? i think it may be the green wire coming off the coil but want to make sure before cuting wire
Thanks
Bradles wrote:[
it should be the negative side of the coil, on any vehicle, for a tacho, no?
