Titties wrote:I would recommend Carl Ruiterman from E&H Motors in Pukekohe.
He was telling me about a starlet they tuned the other month. Something rediculous like 230kwatw from a 1.3... crazy
NZ_AE86 wrote:STM all the way 04 939 0947
Remember that you will get what you pay for where ever you go.
Pay the good money if you want a car that starts cold/hot and idles well etc etc
Any clown can tune a car to make power.
molex wrote:It was actually 240wkw on that starlet E&H motors did, stock standard bottom end with ~130km's.
For what it's worth it cracked a piston a couple weeks after that, to be honest was always going to happen with stock pistons and 22psi. Lasted for countless dyno runs and quite some thrashing before it gave up, thumbs up for the work and the tune
2jayzgte wrote:molex wrote:It was actually 240wkw on that starlet E&H motors did, stock standard bottom end with ~130km's.
So the tune was'nt all that flash if it blew its load a couple of weeks later.I think a good reliable tune that lasts for a long time than a short time is the way to go even if it costs you 10-20 KW as I think it was mentioned earlier I think any competent tuner can tune for a power figure.
2jayzgte wrote:So the tune was'nt all that flash if it blew its load a couple of weeks later
mjrstar wrote:if you are auckland based i would be suggesting kent at speedsource in warkworth.
finx wrote:go see either carl at E&H Motors as said perviously. he did a mint job on the 240wkw starlet. thats things intense!
other option would be robin at torque performance. hes verry onto it with link computers and is well known. also local for you as well...
