Link G3 Tune
Link G3 Tune
Postby spoonza6 » Mon Feb 16, 2009 7:48 pm
anyone recommend someone or somewhere to tune my 92 Toyota Starlet GT with a few mods and a Link G3 installed???
spoonza6
Postby rollaholic » Mon Feb 16, 2009 7:56 pm
might help to mention where in the country you are :)
Postby mjrstar » Mon Feb 16, 2009 8:26 pm
if you are auckland based i would be suggesting kent at speedsource in warkworth.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Titties » Mon Feb 16, 2009 9:03 pm
I would recommend Carl Ruiterman from E&H Motors in Pukekohe.
He was telling me about a starlet they tuned the other month. Something rediculous like 230kwatw from a 1.3... crazy
'98 RS200 Altezza - SOLD
'96 Mitsi Mirage, 11.12 @ 124mph (200kph)
Titties
Postby NZ_AE86 » Tue Feb 17, 2009 9:01 am
STM all the way 04 939 0947
Remember that you will get what you pay for where ever you go.
Pay the good money if you want a car that starts cold/hot and idles well etc etc
Any clown can tune a car to make power.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby spoonza6 » Tue Feb 17, 2009 11:37 am
sorry
yes i am based in auckland but can travel to the waikato and bay of plenty if needed be
haha no clowns needed here jus the ringmaster will do
thanks for your input peoples
spoonza6
Postby JustinSpiderholden » Tue Feb 17, 2009 1:49 pm
Titties wrote:I would recommend Carl Ruiterman from E&H Motors in Pukekohe.
I'd agree with thats or Bob Homewood at Hytech
JustinSpiderholden
Postby 2jayzgte » Tue Feb 17, 2009 4:19 pm
NZ_AE86 wrote:STM all the way 04 939 0947
I would concur with the above he did a good job on my car as well.
Robin@Torque Performance I would have thought would be another good choice.
2jayzgte
Postby molex » Tue Feb 17, 2009 6:04 pm
It was actually 240wkw on that starlet E&H motors did, stock standard bottom end with ~130km's.
For what it's worth it cracked a piston a couple weeks after that, to be honest was always going to happen with stock pistons and 22psi. Lasted for countless dyno runs and quite some thrashing before it gave up, thumbs up for the work and the tune 8)
molex
Postby 2jayzgte » Tue Feb 17, 2009 6:12 pm
molex wrote:It was actually 240wkw on that starlet E&H motors did, stock standard bottom end with ~130km's.
So the tune was'nt all that flash if it blew its load a couple of weeks later.I think a good reliable tune that lasts for a long time than a short time is the way to go even if it costs you 10-20 KW as I think it was mentioned earlier I think any competent tuner can tune for a power figure.
2jayzgte
Postby JustinSpiderholden » Tue Feb 17, 2009 6:28 pm
I hughly doubt the tune would be the reason for this car giving up the ghost. Would be more to do with the 22psi on the stock bottom end and the thrashing it was giving
JustinSpiderholden
Postby iOnic » Tue Feb 17, 2009 6:28 pm
2jayzgte wrote:So the tune was'nt all that flash if it blew its load a couple of weeks later
You don't think it had anything to do with the engine having to produce 3 times the power it was designed to produce without any strengthening? :lol:
Postby molex » Tue Feb 17, 2009 8:07 pm
Motor is being rebuilt with some tougher internals, should be seeing 250kw on about 25psi. 4e-fte pistons crack ringlands, it's the known weakpoint of the engine. The previous tune (also from E&H) was running close to 180kw at the wheels for a long time. After extensive headwork/cams it was retuned to suit and picked up a lot of power, evidently more than the stock ringlands could handle.
To my knowledge this is the most power anybody has managed from a stock block 4e-fte for more than two dyno runs worldwide.
Don't want to turn into a pissing match about power, just wanted to state that Carl from E&H knows his shit.
molex
Postby tsoob » Wed Feb 18, 2009 9:10 am
its not the tune
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Lith » Wed Feb 18, 2009 10:00 am
Yeah I wouldn't knock the tuning of a car having its internals fail after making 184wkw/litre - especially after having previously been thrashed for a while making nearly 140wkw/litre. Thats some solid power for a bog stock motor, I've not heard of any other cars in NZ make that power/litre on a stock engine to be honest.
2007 Mazdaspeed Axela
Lith
Postby spoonza6 » Wed Feb 18, 2009 8:29 pm
impressive
i will go and see Carl and see what he recommends since he has already had a tinker with a G3 in a starlet it wouldnt take long to tune hopefully
cheers for all the info and that 240kw starlet sounds BADASS
heres a pic of it semi finished
spoonza6
Postby cat007 » Wed Feb 18, 2009 8:46 pm
mjrstar wrote:if you are auckland based i would be suggesting kent at speedsource in warkworth.
+1
Postby finx » Wed Feb 18, 2009 9:10 pm
go see either carl at E&H Motors as said perviously. he did a mint job on the 240wkw starlet. thats things intense!
other option would be robin at torque performance. hes verry onto it with link computers and is well known. also local for you as well...
daily: ep71 turbo s 2et 90hp atw 15.5sec 0-400m (stock) current 5efhte + ct9b on 6psi, 13.7@158km , torque steer??
nothing sounds like a 2stroke engine on the rev limiter
finx
Postby mjrstar » Wed Feb 18, 2009 9:43 pm
finx wrote:go see either carl at E&H Motors as said perviously. he did a mint job on the 240wkw starlet. thats things intense!
may check to see what robin is charging these days he was pretty expensive last time i checked...
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
