Burning Angel wrote:if you want a longer lasting and better performing plug you can go for an iridium but they are quite a bit more expensive at $20-$30ea(maybe cheaper if you know someone in the trade or can get discount)
BZG|Bling wrote:Burning Angel wrote:if you want a longer lasting and better performing plug you can go for an iridium but they are quite a bit more expensive at $20-$30ea(maybe cheaper if you know someone in the trade or can get discount)
Are they actually better or do they just last longer?
I heard the copper spark plugs gave a better spark over iridium?
finx wrote:is the car modified at all? if so to what extent. a colder plug will be better for turbocharged vehicle. think the factory ngk rating for the 4efte is a 6 but if it has bigger turbo, increased boost levels and the like i would be going for a 7 or 8 heat range with a smaller gap as well.
need some info on the car to give an accurate answer as to what type you should be getting for it.
tsoob wrote:finx wrote:is the car modified at all? if so to what extent. a colder plug will be better for turbocharged vehicle. think the factory ngk rating for the 4efte is a 6 but if it has bigger turbo, increased boost levels and the like i would be going for a 7 or 8 heat range with a smaller gap as well.
wouldn't you want a bigger gap? a larger spark will surely mean more power? thats how my tuner explained it to me.
sergei wrote:tsoob wrote:finx wrote:is the car modified at all? if so to what extent. a colder plug will be better for turbocharged vehicle. think the factory ngk rating for the 4efte is a 6 but if it has bigger turbo, increased boost levels and the like i would be going for a 7 or 8 heat range with a smaller gap as well.
Size of the spark is not affecting the power of combustion, it either ignites or doesn't.
With higher pressures you need to have smaller gap for same voltage to spark.
It is stupid to think that if you put more powerful coils that you will have more power, it only will work if the current items are inadequate and miss-firing.
tsoob wrote:sergei wrote:tsoob wrote:finx wrote:is the car modified at all? if so to what extent. a colder plug will be better for turbocharged vehicle. think the factory ngk rating for the 4efte is a 6 but if it has bigger turbo, increased boost levels and the like i would be going for a 7 or 8 heat range with a smaller gap as well.
i was more asking about the size of the gap, i remember having a long discussion with my tuner about it and from my memory the size of the gap is very important when you are running high boost
