gt starlet plugs
gt starlet plugs
Postby DOHMAN » Sat Feb 21, 2009 8:25 pm
hey guys im going to replace the spark plugs in my starlet what be the best plugs to get for it at the moment its missing when it warms up and when the revs get high under boost
DOHMAN
Postby Lloyd » Sat Feb 21, 2009 8:48 pm
Whatever standard plugs are listed. Genuine plugs aren't that badly priced either btw
Postby Burning Angel » Sat Feb 21, 2009 8:50 pm
just get the standard NGK or Denso plugs for it. they'll only be $6-$7ea
if you want a longer lasting and better performing plug you can go for an iridium but they are quite a bit more expensive at $20-$30ea(maybe cheaper if you know someone in the trade or can get discount)
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Bling » Sat Feb 21, 2009 9:10 pm
Burning Angel wrote:if you want a longer lasting and better performing plug you can go for an iridium but they are quite a bit more expensive at $20-$30ea(maybe cheaper if you know someone in the trade or can get discount)
Are they actually better or do they just last longer?
I heard the copper spark plugs gave a better spark over iridium?
Postby Twolitre » Sat Feb 21, 2009 10:23 pm
STA parts sells NGK Iridiums for $14 so anyone that pays more for them is getting ripped off. Check out their website as they do deliver.
I'd reccomend just replacing all 4 with NGK BKR6E-11's however the cause of your miss is probably faulty leads, cap and rotor
Twolitre
Postby Burning Angel » Sun Feb 22, 2009 8:45 am
electrons find it easier to jump from a sharp point. copper plugs cant have a sharp point because it would be eroded too quickly.
but in most cases copper plugs will be more than adequate, especially for Vtecs as they take a special plug(bkr6en-11)
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby escortman » Sun Feb 22, 2009 6:08 pm
i only ran $2 ngks in mine went sweet, didnt even change them after the run in tune
4x4 toyota blizzard offroader
escortman
Postby finx » Sun Feb 22, 2009 6:34 pm
is the car modified at all? if so to what extent. a colder plug will be better for turbocharged vehicle. think the factory ngk rating for the 4efte is a 6 but if it has bigger turbo, increased boost levels and the like i would be going for a 7 or 8 heat range with a smaller gap as well.
need some info on the car to give an accurate answer as to what type you should be getting for it.
daily: ep71 turbo s 2et 90hp atw 15.5sec 0-400m (stock) current 5efhte + ct9b on 6psi, 13.7@158km , torque steer??
nothing sounds like a 2stroke engine on the rev limiter
finx
Postby DOHMAN » Mon Feb 23, 2009 8:33 pm
na no major mods just a pod filter external wastgate its runnin about 10psi think i mite just replace them with standard plugs and standard leads giong to get the timing cheacked tommorow
DOHMAN
Postby finx » Mon Feb 23, 2009 10:17 pm
if its a fairly stock set up then yes the listing for stock plugs will be fine.
go for ngk plugs. bkr6e11 is the part no
finx
Postby tsoob » Tue Feb 24, 2009 11:04 am
finx wrote:is the car modified at all? if so to what extent. a colder plug will be better for turbocharged vehicle. think the factory ngk rating for the 4efte is a 6 but if it has bigger turbo, increased boost levels and the like i would be going for a 7 or 8 heat range with a smaller gap as well.
wouldn't you want a bigger gap? a larger spark will surely mean more power? thats how my tuner explained it to me.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby sergei » Tue Feb 24, 2009 11:16 am
Size of the spark is not affecting the power of combustion, it either ignites or doesn't.
With higher pressures you need to have smaller gap for same voltage to spark.
It is stupid to think that if you put more powerful coils that you will have more power, it only will work if the current items are inadequate and miss-firing.
Postby tsoob » Tue Feb 24, 2009 3:45 pm
i was more asking about the size of the gap, i remember having a long discussion with my tuner about it and from my memory the size of the gap is very important when you are running high boost
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby sergei » Tue Feb 24, 2009 3:47 pm
The higher the boost the lower the gap for same coil voltage and spark plug.
Postby finx » Tue Feb 24, 2009 6:26 pm
if the distance the high voltage charge has to jump is to big in a high boost or high compression situation the increased pressure in the combustion chamber can interfere with the spark which cause's piking and pre ignition. so you require a smaller gap.
a larger gap will mean it is harder for the high voltage charge to jump and cause spark. combine this with increased cylinder pressure and you start running into issues with not enough spark as it cant make its way to ground.
you can do things like plug indexing and the likes to gain power but it will be very little, very expencive (unless you have a dyno if your garage). and is only really used in race applications where cars are spec limited or maxing out potential hp.
finx
Postby DOHMAN » Tue Feb 24, 2009 9:03 pm
went into repco today priced up the standard plugs which are platnum plugs they were bout $30 a plug
DOHMAN
Postby johndoe1025 » Tue Feb 24, 2009 9:52 pm
thats ripco for ya, try bnt or similar
johndoe1025
Postby DOHMAN » Thu Feb 26, 2009 8:22 pm
plugs done all fixed no more miss at high revs :lol:
DOHMAN
Postby DOHMAN » Sat Feb 28, 2009 8:40 pm
ok tell a lie the miss is back im goin to get the leads checked out by my mechanic when he has a look at the idle speed controller as its idling at 2000rpm
DOHMAN
Postby finx » Sun Mar 01, 2009 8:32 pm
there is an idle adjustment screw on the top of the throtal body under a black blanking cap wind it in untill it is set right. if its still to high i would be looking at a possible vacume leak from the intercooler/piping or inlet manifold and aux hoses.
can also idle high if air con has been removed. there is a plug that needs bridging.
leads are easy to check. any excessive dirt or oil on them will trace spark, also check the ends are all making good conections for starters.
finx
