***how to hook up tacho to link ecu****
Postby stefegg89 » Wed Feb 25, 2009 6:44 pm
im trying to suss my monster tacho to the link ecu and im not to shore how i have been told you have to find a wire on the lnik ecu 1st to hook it to and i have twin coil packs im not to shore bout them either is it simple
stefegg89
Postby AceSniper » Wed Feb 25, 2009 6:53 pm
depends what version link?
older ones have a shiftlight/tach output that you can config also the 3rd ign channel is tach.
not sure with newer ones but no doubt there will be a output wire you can config to tach.
AceSniper
Postby matt dunn » Wed Feb 25, 2009 6:54 pm
running a tacho that is designed for coil -ve signal off the link signal,
is hit and miss if it works ( mostly miss as they dont)
as the link puts out a square wave and most tacho's look for the high voltage coil -ve spike.
Get a tach adapter off a mitsi, someone on here should have one.
Postby spoonza6 » Wed Feb 25, 2009 7:19 pm
i got a spare one
where you located?
its a tacho interface from a dual coil pack from a 4G63
spoonza6
Postby stefegg89 » Wed Feb 25, 2009 8:24 pm
the tacho i got is a autogauge 5inch with a big shift lite
will i need one of those adapters
stefegg89
Postby spoonza6 » Wed Feb 25, 2009 9:18 pm
more important
what link do you have?
spoonza6
Postby matt dunn » Wed Feb 25, 2009 10:31 pm
stefegg89 wrote:the tacho i got is a autogauge 5inch with a big shift lite
Yes because autogauge is a crap brand, and wont trigger off a link signal
Postby matt dunn » Wed Feb 25, 2009 10:33 pm
spoonza6 wrote:more important
doesn't matter as early or late, they all put out a square wave signal,
which cheap brand tacho's dont normally run off.
Postby stefegg89 » Fri Feb 27, 2009 6:44 pm
its a autometer sorry the black 1 they retail at like 350$ still
stefegg89
Postby 3T-Rona » Sat Feb 28, 2009 7:23 pm
i have a tacho interface in Tauranga if you want one.
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
